Hey guys I’m thinking about running a shot of Nos on My R33 Skyline.
I don’t know how the Engine will react to this so I’m just asking around if anyone has done it or if they can give me some advice.
The only modification that’s car done to my car is:
• FMIC
• 3’’ Turbo back Exhaust with High Flow cat
• Standard turbo High flowed
• Heavy duty clutch (extreme)
• Bosh 044 pump
At 7psi she pushed 182kw@the wheels on Dr drifts dyno.
I was thinking of a dry system and a 70hp shot of nos.
I dont want to do much engine work, i was told that the engine is good enough for around 300kw @ the wheels??
I don’t know much about NOS systems. So any help will be grateful.
Thank you very much:D
Edited by Dush
https://www.sau.com.au/forums/topic/129203-rb25det-with-nos/
It would be a cool thing to have in your interior so you can 'hit the NOS'. But seriously maybe a dual stage boost controller set between stock and about 14psi will have a similar effect. Cant see the practicality of a nitrous system especially the defect factor
Regardless of what people have been telling you, you can run 100 wet shot comfortably, all you need is fuel pump upgrade which you already have, Aftermarket engine management e.g PFC and the Kit. with the correct tune the car will make around 250rwkw and be capable of mid 11sec passes. This is not a toy for the street though. and we will soon see how heavy duty your clutch is. You can buy wet kits starting from $990 which include everything to get started, just need to add bottle warmer $ pressure guage to tune. Dry systems require the fuel to be added through the injector rail and sometimes require the upgrade of injectors. is not something you can fine tune urself unless you have extensive knowledge of tuning with PFC or ECU you decide to use. People on this forum have been running the bottle for a couple of seasons know with no engine failures. By far the best bang for your buck.
• FMIC
• 3’’ Turbo back Exhaust with High Flow car
• Bosh 044 pump
As long as you are able to adjust ignition timing with it, then yes it would work. need to pull total timing out when the gas is on. A/F you adjust with fuel and bottle pressure & different pill sizes. In saying that if you are looking to get maximum performance out of your car a stand alone may be necessary as to get full potential out of the tune before you add the gas. Can run 1 bar of boost and 100 shot on standard engine with standard injectors etc.
so to run a 50-70hp shot of gas you would need a Stand alone computer and a piggy back wouldnt work???????????????
Edited by BezerkR32
Get the car tuned first, then pull around 4deg timing total out. use pills recommended in kit. these are on the fat side. start from there. Start with 900psi bottle pressure. will need a Air fuel meter to do this. best done on track. Not familiar with too many shops in Melbourne as i am from wollongong but buy kit from Barney at VPW and he should be able to advise you on who too see.
Thankx for your help guys.. i get a ECU first befor i strap the bottle.. is their any good workshops in Melbourne that have extensive knowledge in tuning nos systems?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
