  • 1 year later...
  • Replies 78
It's been a long time since this thread was around and since there are so many newbies in the Stagea Section I thought it was about time to resurrect it so you can add to the list and reveal all about the mystery surrounding your sign in names.
For an explanantion on what the thread is about, go the original post on page 1.
*kicks things off*
Mine is actually my nickname given to me by my (then) 5 year old daughter. She used to be called "little chicken" as well as all the other usual baby names, but one day I was changing a nappy and called her "Stinky Chicken" and it just sort of stuck. Years later she decided that I should be called Stinky Rooster.
So, to all those that asked, it is NOT because I have extra fragrant genitailia......
As a keen jetskier and having destroyed many jetski's in my day I was looking for a new name for online gaming and just happened to be looking out into the backyard at a recently destroyed Seadoo XP Limited(Bit tipsy at the time if I am recalling the story right).
Anyway didn't mind it, people remember it and now I'm used to it.
this is an aoursome thread glad to see we can keep it alive.
Now my nuser name. i wanted somthing thast unique and i use petrolfix all across the net.
it came about cos me and my step brother (at the time, god rest his soul) had dreams of opeaning a performance shop we where coming up with names to call it, piston-perrfection was the one we decided on at the time but our second coice was petrolfix.
Petrolfix itself came about as a we both where driven by cars. all ways watching motor sport, ralling cars reading magazines, unless it had a motor i'm not interested. I have been a petrolhead all my life and as i get older the addiction gets worse. The same way a drug addict needs a fix I need a fix for my thurst for petrol powerd machines
(just like my signiture reads)
Helloooo Springfield
My name is Mister E
It comes from the Band the Eels the lead singer calls himself MR. E and I like the band so I blantantly stole His name.
I also like how when you say it quickly its like Mystery....at least it does in my mind. I'm not going to sit here at my desk at work and say mystery over and over again.
I dont think i should mention how i got mine or what it means but i got it a few years ago :)
I am apparently wild and cat is um..................... :rofl: well use your imaginations and it will come to you :D
Use that nick in everything i do and am even going to get the plates for the stag with that :P
That is the best reply in this thread thus far. :D
Xmetal is something i've been using now since 1997, It was an object of my desires to start with but I grew to use it on everything I do, it's even my business name now for my photography. :) (events, weddings, automotive) *shameless plug* :P
My nickname is actually my nickname my mates gave me since year 12. The Big is because i'm tall. The Dirty part of my nickname is from playing video games (was always the one with sneaky move or shot on someone) and Jase is my name. The nickname has stuck for a long time
There you have it
Edited by BigDirtyJase
Well, the day I was born, the moon was in its 3rd phase, and Jupiter was aligned with Mercury. It was exactly 17 weeks since the last Solar eclipse, and a white dove had been seen overhead for the three days prior to that of my birth....
I was always known for being blatantly obvious. Still am. AlthougI go as Mickeyb on most other sites.
Man, am I boring...
English Translation: "Man with very small pee pee"
I resent that remark! I'm more a boy that a man!!
(you need to have Japanese text support on your PC to read my username)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
