Have a few parts for sale.
Apexi PowerFC to suit BNR34 with Hand controller- AS New, initialisation done, partially tuned. Bought from trader in SAU. $850
Nismo AFMs - same flow as Z32 AFM but in stock 65mm size. $SOLD
Reason for sale: decided to go with MAP sensor ECU.
Nismo low temp thermostats - As new, fully open at 62c, only fitted for tuning, no box. $SOLD
Reason for sale: working too well with aftermarket radiator. works best with stock radiator.
Nismo racing spark plugs (22401-RS238-8) - Brand new. $ 150 for 6.
HKS speed limiter defender - remove speed limiter, used. $ 80
Stock BNR34 used parts:
Stock BNR34 GTR intercooler - excellent condition. SOLD
Stock BNR34 GTR turbos - 30,0000km of use. $SOLD
Stock BNR34 GTR suspension - 30,000km of use. Suit R33 GTR $400 for the set
Stock BNR34 GTR stock cam gears & cams - $ offer.
Stock BNR34 GTR cat converter - metal cat - $ 150.
Stock BNR34 GTR engine mount/transmission mounts, suit R32,R33,R34 GTR $120 for 3.
Please PM or email [email protected]
Edited by baboo
thermostat bolts to the engine. not the radiator. :)
interested in the nismo AFMs. how flexible on price are you? :)
Just to clarify with BNR34 turbo Specs.
They have ceremic wheels.
BNR34 ......Serial No. 14411-AA300 (Ball bearing centre)
C100 Compressor with a 0.53 A/R and 50T
T25 Turbine with a 0.48 A/R and 62T
If the thermal stat opens at 62 degree, does that mean my car's water temp will stay at 62 degree or its just open ealier than standard thermal stat?
Thanks
It means the thermostat start opening up at 62 degrees ( stock one opens up at 76.5 degrees)
your water temp will be higher than 62 degrees, presumably around 80~85 degree when it's upto working temp.
The thermostat is sold to satanic
I have 34GTR turbos in my 32GTR, just to let all know that they will fit :P
Come to think of it, I was sure mine had T03 written on them somewhere :D
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
