Hi guys,
Once in a while the factory boost gauge will cut out on the R34.
Has anyone seen this before and know what could be causing just that particular gauge to not work? It comes on again after a while though.
Cheers
Howie
Holy Shit man!!! :dry:
Your oil temp is so high! Mine never goes above the next line after 70... mine is always around 90 degrees (1/4 line), where yours is at like 115 degrees or so? Is that normal, or where you just flogging the shit out of it?
LOL... you're seeing things... stay off the crack man :D haha
^^have a look again buddy its below 90 degrees.
never had that happen to me, check all your wires and plugs
Okay so it's probably not a common problem, i think i've got a grounding issue somewhere. Guess i'll just have to sit down for a day and trace it down.
well this might be a bit off topic, but with the voltage guage there, is it normal for it to flivk up and down as the indicators flash. when i saw it it seemed pretty normal to me, but then i was told that it shouldnt do that. what do u guys find happens? is it steady or moving with every flash of the indicators etc?
It shouldn't do that.
Also re boost gauge, check the sender unit which is mounted up high on the firewall in the middle near the brake lines on a bracket. Sometimes the connector that the hose goes to snaps. Also trace back along this hose. There is a one way valve whose connector also breaks quite often.
If these connectors are snapped but still holding on they might show boost sometimes but not others.
But.. although they are well worth checking I suspect your problem is electrical but most likely based around the sender unit.
  • 1 year later...
sorry abo bob but the sender you've posted is the boost sender for the ecu, the boost sender for the in cabin gauge is seperate and is located inbetween the guard and the brake master cylinder, its a larger oval shaped unit, pretty hard to miss if you look where i said
one of my mates has the same problem as well, but havnt had enough time to have a good look at it, we gunna try swapping the sender units over and see if that stops it, if not then yeh it'd be a wiring problem.
Edited by s13_Skyline_inside
i got this problem also, its fine now after i change the boost sensor.boostsensor.JPG
Edited by reno chin GTT
thats the one im talking about, so Wogboy with your son's one you opened the sensor up and was just a loose connection, can it be soldered with normal soldering or is dry solder something different?
the only reason my volt gauge goes down is when the sub is pumping... not for little things like indicators...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
