  • Replies 422
Posted Images
If you get called in you'll be going faster and making more power than any of us, so I guess that's some consolation.
Good point well presented - something about 18,400 hp that still makes me smile.......now if we can only strap it on the dyno........
No problem to those who want to come, need to keep the deposits coming! Please pm me if you want to come and ill send you the bank details.
Enrico - No problem
Drift - Yeah bring your mate, leave a deposit and secure your place!
Cheers everyone.
busky, yeh mate got me a s15, love it, and its stock!!
Im interested in your car, i looked at your website, we need to have a chat!
Got a Xr6 turbo for sale, lovely car with 26000ks on it.
Let me know if anyone interested.
Long time no see indeed!
Nice choice on the S15, Dean - I still love mine even though I am trying to sell her ;) .... every time I drive it I get a huge smile on my face.
I tell u what, like i said, even in stock form this car is so much fun. I cant wait once its modded.
Good luck sellin yours, ive seen it advertised, and its definately a bargin for the amount of money you have spent on it, and how well its been looked after.
Lookin forward to catchin up with u lot soon
Turned to the dark side Enrico? Nice :huh: Enjoy the S15! Nice car!
My website is old because I sold the car. So I pulled the link to it. Got another S14 now with a bit more work done to it hehe. Catchya at the dyno day if I am able to make it!
busky, i hear u have a t518z? 10cm aswell? Thats what im lookin at
i have a HKS2540 (shaft play) sitting on my cupboard
bought it for my s15 but never get the fund to rebuild it (your choice of 25-30/35/40)
and the car is now gone :P
send me a PM if u are interest
Edited by Maxx
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
