Just a quick update to let you know who has paid a deposit. Just to confirm aswell. Make sure if you have left a deposit that your on this list! If i have missed you let me know, and if you have transfered a deposit recently dont stress as it takes a few days for it to show.
Cheers. Looks to be a good day, to anyone out there that wants to secure thier spot on for a run please contact me and ill send you the deposit details.
3. gtrGhosTDoGG11 paid *
4. DriftR_33 paid * 2 people
6. vange paid *
8. Nightcrawler paid *
11. Mr X paid *
14. mr_rbman paid * infull
16. Madaz paid *
19. chops paid *
23. Lee paid *
24. Crimmo paid *
25. Rolls paid *
28. Shannon paid *
Edited by gtrGhosTDoGG11
  • Replies 422
Posted Images
did u finaly recieve payment from shannon?
if so he isnt able to make it now due to going interstate weekend before was perfect for him ... not too worrie
but keep his payment as the rest of mine and lee's run and well sort out wot is owing on the day
Edited by Madaz
6. vange paid *
11. Mr X paid *
16. Madaz paid *
19. chops paid *
23. Lee paid *
24. Crimmo paid *
25. Rolls paid *
28. Shannon paid *
Can I deposit the lot at once into the account? main reason being that it cost's $5.00 for the transfer? (BankSA) Or prefer the $10.00 and $15.00
should cost nothing for direct deposits sux to be with BSA
I'd have to agree to that. I'll start looking around at various rates with other banks/businesses to get the most out of hard earned cash. By some chance Madaz are you removing some form of drive to allow for two wheels only? or is Shauns dyno awd? been there plenty of times but never took notice of this fact :s
Just wanted to know whether he minds having the whole $25.00 directly deposited, or still the $15.00 on the day and $10.00 deposit
gtrGhosTDoGG11: looks like shannons payment made it too a William Q Ho im guessing this is you ?
and description should either be a random number plate or Shannon Blackwell-King
he paid 25 dollars
Deposit paid ghosty, i could get few more chasers if want?
Erin
So...should we get some VL's in if we don't have enough numbers? were we looking for about 25 overall? (approx). If need be i can get one VL turbs to come.....
So.....do we need some more numbers? If so let me know and i'll grab a VL for you, nothing outrageous, just family relative. Also, money is in the account, so will see it no later that Wednesday :) (that's what the lady told me at the counter :O).
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
