hey guys i got a power fc on my r33. i was just wondering if my power fc reads a temp of over 90 after a while of driving should i be worried? the temperatire needle is always on half way so it seems ok there, but just wondering what should the average reading of the water temp on the power fc be.
cheers
https://www.sau.com.au/forums/topic/129938-rb25det-water-temp/
Hmmm... How high over 90? 99 or 91?
There is a bit difference between the two. :)
If its 90/91 i wouldnt be worried, depends on other factors aswell.
Cruising 100km/h is it the same?
Is it only that temp in peak hour traffic?
Bit more info dude, but it sounds ok at this stage.
don't worry its nothing
my old man's corvette gets up to 110deg in traffic before the fan comes on
remember the water is under pressure so it boils at a much higher temperature than normal water. plus there's the anti-boil added that should assist even further..
The thermostat is 82 deg C??? On the street my handset say about 82-85. So for potting around the thermostat isnt cracking???? Or should i be checking that mine is ajmmed open. Because my temps sit so low on the street, i normally pull the pin at the track when the temp gets to around 90-95 (depends how much lomger the session is and how hot ther dy is etc if i push past 93 etc
82-85 on the street is A-OK Roy. The temp sender may not be accurate to the degree but most engine temps sit at or just above the thermostat temp. On hotter summer days it'll be 5-10C higher than the thermostat temp. Normally a thermostat will close roughly 5C lower than its set temperature.
Also I think high 90s is OK for the track. I'd probably think about pullin the plug when its more like 110C? Remember with a proper cap + coolant it wont boil until 120C.
Cool
Roy,
I think the other dude meant to say the 'R34' thermostat begins to open at 82degree's.
The R32/R33 on the other hand begins at 76degree's.
If the thermostat is genuine or not also depicts the cars operating temperature and how quickly the thermostat opens completely. The genuine opens slow and by little amounts until its nice and hot. This results in a slightly warmer running temp with less fluctuations and a considerably quicker warmup.
The aftermarkets (supercrap autostores etc) open wide and really quickly, the aftermarkets also take ages for the car to reach operating temp from a cold start. On my sisters VL it would tend to run hotter under consistent load with the aftermarket but run cooler just pottering around, in the R32 I haven't seen this problem, it simply ran cool all the time; all though I didn't get to 'really' test it out in hot weather. I dropped the genuine thermostat in the VL as it ran much better and wouldn't over heat when giving it a boot full up willunga hill.
Both genuine and aftermarkets are rated to 76.5degree's.
(I sound like a record) I recently said the same in another thread. :(
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
