hey guys,
i reallly need some serious assistance. i have to make the decision between selling my nissan skyline r33 gtst and getting a bmw328i convertable or keeping the skyline.......what should i do? PLEASE HELP lol i need some advice
Thanks
Edited by magpies03
https://www.sau.com.au/forums/topic/130306-need-advice-on-car-purchase/
hey guys,
Thanks
Stick with the rice!
