  • Replies 46
Guest neoGT-25
your friend is exactly right... i live on government road in a townhouse complex :P
oh and to answer the "U say in there (from 174kw to 188kw) how did u get to 174kw.. i thought they were 145kw stock..?" question
i dont know... its just what the mag said... i dont drive yet so it would be had to cruise LOL
what school did you go to? i go to benowa and its a crap school :P
and also i wouldent know where to buy parts :P
hehe... byes :burnout:
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252013
haha madness man, i cant beilve u have a r34 and u are still in school u lucky basterd :P
yer i was at helensvale high man graduated in 99, yer that was a wicked school i had some good times there.
i lied im not really in biggara water i live about 2 mins from u u know whiting street...brown st im just down there :P
small world :P
are u licenced to drive it yet or not??
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252065
From what martin donnan said about his partners car
R33 door, auto RB25DE,
he recorded a 9% increase in power at the wheels with a 5zigen cat back exhaust.
impressive i think.
cam shafts, i have heard u can install some tomei cams, that dont requre ecu upgrades,and provide a 10% increase as well, get some adjustable cam gears to dial in as well.
An altenative to getting totally new cams is to reground the existing cams, though a side effect could be roughness in the idle, but i think i could live with that. :P
SAFC will make the most of you cars stock air/fuel ratio by maximising it.
i am desperatly saving for all of the above, and through a top bloke i could land my self a 5zigen R33 na cat back, wahoo
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252261
Just read that HPI article on NA tuning.
The results that they got, are CRAP.
after a cat back, 2 different extractors, 2 HKS camshafts with cam gears. And an apexi SAFC.
its only 88rwkw, up from about 72/74rwkw. Shit in my opinion.
i plan on getting all the mods mentioned, and from the research ive done, i will make alot more then 15rwkw
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-255238
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
