Hi,
finally put in the HID kit into my R34, 8500k, thought was going to be stupidly blue but was pleasantly surprised, was actually ok.
But the light is still nothing special though, quite disappointed actually, and i think my headlights are pointing too far down. I've got the switch in the car that tilts the lights up and down, it does work, and i've got it as high as it will go but the light is still very low (angle).
Is there are a screw or something to manually life the anlge of light on 34 headlights?
cheers,
daniel
i found 1 screw which is running vertically behind the assembly, which then runs into this white plastic cog setup, i turned that but didn't do anything to the light angle.
When i had the head lights i did find another similar thing, but didn't have a philips head, it's was a hexagon shaped head but quite small, like maybe 5mm across??
when i was turning the screw one, it just started clicking on me after a bit too, like it was trying to do something, but it just wasn't happening.
also, HOW would it go up or down? It's bolted to the car in 4 different places... i can't really see it moving much...
man, compliance has seriously made the headlights just down right dangerous. so much for adhering to ADR's due to "safetey" reasons... what a load of bollocks :D
HID conversion kits in halogen reflectors suck (read: dont work like they should)
your headlights are oging to be screwed until you put halogen bulbs back in
also 8500k isnt brighter than 4300k
also the blue will make you tired on long drives
but i have the OEM Xenon assembly (see my sig pic), i thought it would be ok if put some Xenon's back in... it's hard to tell until i raise them up a bit i reckon..
i have heard retro fitting HID kits doesn't work, but i thought it would be different as mine were factory Xenon just replaced with halogen.
I know 8500k refers to colour, but was just worried bout the blueness, it's actually not as bad as i thought (or seen) -
i can't see how OEM R34 Xenons would make any difference to the light cut-off/shape? it's just a different bulb yeah?
Have you seen what the OEM xenons look like? They're a lot less "harsh" than HID Kits... it's very bright; but in a way which is non-intrusive. Dunno how they did it but my bet would be in the actual headlight assembly.
i might ring the mob in sydney who do the conversions, pick their brains. might take it down to a nissan dealer, see if they know anything about adjusting the angle. Says i can got to a dealer in my manual :D
if its factory xenon
it should work
do you know if they were they re-aimed for halogen bulbs?
Hi,
cheers,
daniel
What did I say in that Xenon thread!!!??? Nice light but too low and poor throw....
No one listens to me :huh:
went to nissan,
1) they don't sell nor can get in OEM Nissan Xenon globes :) -
2) they showed me two adjustment screws/cogs - 1 left/right, 1 for up/down (i'm not convinced my up/down works)
3) they said putting in Nissan globes wouldn't make a difference to light cutoff, they said if you've got Xenon globes in there, you've got Xenon globes in there.
i'm not convinced they knew much anyway...
is this what ppl's R34 Xenon headlights look like on the inside?
what is the cut-off like for OEM Xenon's anyway? is it as good as say the Honda Euro lights?
greg, you got the car mate!! PICSORBAN!!! i wanna see my rims :O
greg, you got the car mate!! PICSORBAN!!! i wanna see my rims :)
OEM xenons in reflectors wont have a cutoff
i mean the light cut-off thaka, if u see a honda Euro projector, there is a nice line. So it's either "light" or "no-light" there's no inbetween. Watch a OEM xenon car go down a small street one time, look at the side of the road, you'll see a nice clean cut-off, really noticable when it goes of speed bumps or something.
and how would one turn these? the closest one spins free like anything, the back one isn't too happy to move....
the above cog (i used to turn with a flathead screw driver) adjust the Hi-beam up/down.
The screws on the far side of each assembly (closest to the front guards) control low-beam left/right but i haven't found anything adjusts the lo-beam up/down - i'm not sure if there is a manual adjustment for it as they have the electronic switch in the car.
does anyone know, definitively, that there is an MANUAL up/down adjustment for the lo-beam on R34 Xenon assembly's?
cheers,
daniel
  • 1 year later...
man i look young in this thread :(
the adjustments are there mate, i just can't remember where!! hahaha, we did find them when i had my car resprayed. Just hunt around, the white cogs are the hi-beam or side-to-side, and i think there are small "hex" bolts which are quite long, that adjust the low beam up/down
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
