1) As someone mentioned, it was the happy snap camera attached to the number plate
2) I was waiting for someone to say that.
The car came lowered (on Cusco coilovers), however the dump pipes were like 2 inches off the ground. I use the car for work purposes (when I get the opportunity) and travel through some country areas where pot holes / big deep ditches can be found.
I raised the car to get over the pits first, however after using it at its current raised height for the past few weeks I absolutely love it!! It's not crashing over anything and I don't have to drive on a 45degree angle in car parks or to get up steep driveways. I plan to paint and repair the front lip (couple joins broken), so the raised height will also come in handy in keeping that in good condition.
Sure lowered looks hot, but meh I'm over the whole looks thing. My mum says it sounds like a truck, and now I can say it looks like one too :woot:
3) The front bar is genuine GT-R, and yes you are correct its a GTR (V-Spec) as well lol. Everything exterior wise is original, except for the Nismo bonnet lip & smoked lenses.
Matty,
Cheers mate.... yeah, I must say... who cares what others think of your ride - it's your ride and you wanna ride it quite comfortably... e.g. my car, it's got original springs and height... I like it like that as it's comfortable - sure, looks a bit shit but who cares... sure of going on an agle over bumps and getting my front bar cracked all the time... not to mention feeling every twig and stone on the ground... nice put buddy...
Nice ride... I would just give it a good wax job and done... the R33 GTR is by far the hottest GTR ever...
Cheers,
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
