heres another one, wheels are 17x9 +22 all round.
thanks
Thats awesome
Wow got any more photos, best 33 since granthem's
Haha cheers mate! Hope it doesn't change your opinion, but mines currently undergoing some cosmetic surgery :D
Combination of changing the cars style (since I think the Enkeis suited the more "racey" look, but the meister will be more suited to less lairyness) and the fact I hated by stupid fibreglass front bar with a passion.
Felt like doing a timeline of my car after seeing granthem's post
Car when i bought it
Eventually scraped walls and stitched it up
Changed Stitching Pattern and Rattle canned the scrap so it looked cleaner
Smashed it into a tyre stack at Wakefield Drift Day, borrowed a drill and repaired it between sessions
Solve the puzzle
Good as new with about 50 cable ties later
Thought the front bar would attract too much unwanted attention so got a full kit for 200 bucks and came with this trust front bar
Got defected so went for a more stock looking car
Got sick of people saying red front bar looks dodgy and also saw old pictures of my car
So painted the front bar white and also got a lip
Wanted a cleaner look so painted the front lip
Takz your timeline is insane. You can;'t be called a hardparker thats for sure!
While my new bars are being painted, my best mate spend some time doing some paint correction on the whale.
Results are below :D (crappy iphone pics, but you get the gist of it - im super happy!)
blaq's leading the viva garage lip and 4 door foggie phase!
i want your ganadors!
Visionary genius :D
And thanks for making me regret selling my RPF1's blags!
Alright guys, got ma new grillz (Nelly voice) - what do you think? I'm fairly diggin it. Its only a test fit, not all clips are on the grill so its sitting abit funny
The grill is a series 2 4 door item. Don't see many of them so I snapped it up.
Its missing some clips off the back tho. God knows whew I am gonna find any to replace em with. I was thinking panel beaters would require new clips frequently?
cable ties brah
I have a pack of my highest quality black cable ties at the ready as a last resort!
If you wanna sell the grill let me know! haha
Haha took me a while to find it actually! Hoping it matches my 4 door grills under my foggies well :D
If it doesnt - its yours
few pics of my car atm. not 100 complete, bar is just sitting on there. got a Bond cage to go in it and quite a few other odds and ends, brake ducting etc new oil cooler. its registered (was my daily for 3 years) but wont be seing much road use now, hoping to do all the hillclimbs in Tas next year and all the suppersprints plus a few private days, should see atleast one event per month and atleast one small road outing a fortnight in the nice weather =D
cheers
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
