yeah im not a fan either, but i have seen a few good ones. one of the guys up here has a 33GTR LM, it came from Japan with some nice red lens LED's theyre nice, but no one knows what they are exactly (not that Ive looked into it at all)
go original, they are the best :)
The r33 out in daylight for once. Only showing a pic of the front as the tail lights have water in them, need to find a set of aftermarket led units that don't look cheap...
I have a mint set of factory tail lights from my '98 if you are interested
Nice car :)
good luck with that. very few of them are nice, i'd suggest going for red lensed LED's. they look neater than the clear ones.
Oh, I see how it is Bodo! :nyaanyaa:
you know how i feel about your tail lights :sick: , think it was one of the first things i said to you when we met...and before i knew it was even your car :P
although the crystal clear indicators and reverse lights are nice. i'd like those but with the stock tail light lenses
Haha apparently not
But yea the mentioned indicator and reverse light section is at least half the reason I have them
But since ya hate them so much, im gonna post a pic to make you look at them! Muahahaha :P
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
