After "Nurse Debbie's" little chat last night, you now all know why we need to give blood.
My next appointment (it will be my 94th!) is scheduled for after 30 August. While I ordinarily donate mid-week at the Bourke St centre, I'm willing to make a change to a Sunday at Southbank. To do this, I need your support.
If you are genuinely intertested in becoming a blood donor, please email me with your intention. I need to know by Friday next week (August 25) so I can try and organise a group booking on the 3rd or 10th September.
https://www.sau.com.au/forums/topic/130529-give-blood/
Reminder that some of us are giving blood Sunday (September 24) at the Red Cross's Southbank centre (Cnr Balston and Kavanagh Sts, South Melbourne). If you aren't giving, why not cvome along to lend moral support.
https://www.sau.com.au/forums/topic/130529-give-blood/#findComment-2510599
You need to have eaten something before you donate. I suppose we could do "morning tea" afterwards, although Red Cross supplies all those yummy nibblies after your donation.
And you need to have had a reasonable intake of fluids beforehand as well (NON-alcoholic, Brisby!!!!).
https://www.sau.com.au/forums/topic/130529-give-blood/#findComment-2513421
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
