Saw some pics of a pretty smart looking Black M35 (post #50) at
http://forums.freshalloy.com/showthread.ph...1822&page=2
which I think is going to be the 2007 model Skyline looking at the Nissan site
http://www2.nissan.co.jp/SKYLINE/NEW
I think it looks a bit better than the current V35, maybe Australia will get them, apparently Nissan NZ is looking at bringing them in because they are getting so many people wanting a 350Z with 4 doors!
Who knows maybe Nissan will bring these in to complement the next GTR!
I won't be holding my breath but here's hoping!
Edited by gts4diehard
https://www.sau.com.au/forums/topic/130559-infiniti-m35/
V6 (M35) and V8 (M45) export versions of the Nissan Fuga...
No it's not, the Fuga is one body size up from the Skyline. The 'Next Skyline' in that link you posted just looks a little like the Fuga... which looks a little like a V35... which looks a little like a Murano... which looks a little like a Tiida...
https://www.sau.com.au/forums/topic/130559-infiniti-m35/#findComment-2416123
  • 4 weeks later...
Great car...have seen many American ads. (INFINITY)
I thought that this was the car that was being launched when the Maxima(New shape) arrived .
I had read the stats. and though this is the car for me........
As usual Nissan just gave us the crap and keeped the best for America. :)
https://www.sau.com.au/forums/topic/130559-infiniti-m35/#findComment-2496068
  • 4 weeks later...
Yeah imagine if Nissan, Toyota etc, etc, bought out decent rear wheel drive cars here.
Instead of boring FWD v6's that are too soft. How cool would it be if they bought in the Fuga, Aristo, etc, etc.
Aussies would get the V8 they love and RWD which they love.
And that would be nicer than any Holden or Ford in my opinion.
https://www.sau.com.au/forums/topic/130559-infiniti-m35/#findComment-2603238
  • 1 month later...
Volume-------USA-------small margin-----$$$$$$$$$$
Limited--------AUS-------large margin-----nothing to write home about...lol :laugh:
https://www.sau.com.au/forums/topic/130559-infiniti-m35/#findComment-2711978
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
