Just thought I'd show you lot a photo or two of some recently fitted wheels. Eagle eyed SAU'ers may well recognise the car from some of the 'small' details,LOL!
I personally thought these were sexy as all heck...Pass the Kleenex,I say!
https://www.sau.com.au/forums/topic/130808-sexy-preview/
  • Replies 40
Posted Images
a guy on SAU was selling them i was actually seriously considering buying them and am probably shooting myself in the foot for posting it up for you chumps but check out this post....
If someone wants to buy my rims for an ok amount i will buy these hehe
http://www.skylinesaustralia.com/forums/in...=128741&hl=
I would LOVE GTCs but at $3500 for 18s without tyres... :P
love the carbon lip. thats HAWT!
https://www.sau.com.au/forums/topic/130808-sexy-preview/#findComment-2426178
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
