These just a straight swap on a R33 GTST? (the front grooved dimpled's i'm talking?)
If so, put me down for a set of fronts and rears
One sec i'll get the number, 7693, 908 i believe.
When is this closing?
Edited by nsanity
  • Replies 245
Posted Images
Hi, It's not closing yet I'm waiting for scott from RDA to come back from his leave, hopefully he is in tomorrow (monday) and I'll ring him tomorrow.
I'll send you a pm ASAP to get your details when orders will be put through, but I'll confirm the final discount price and let you all know.
7693 front & 908 rear are correct, they will swap straight to your standard original rotor and fit the original calipers. The more expensive one you mean slotted & dimpled, right?
Yes, 908 is the part no. I'll update the list tonight after work.
I am interested in a set for the front.......GTR33 Slotted.
So what is the final pricing on these?
Cheers
Tekin
nsanity,
Ive got u listed as front and rears. there's two lines there, the line below your name don't have the number 26, that one is still belong to you. sorry but I can't find a way in this forum to post with table structures, so it's kinda quirky.
26 nsanity R33 GTS-t single turbo 7693 Dimpled & Slotted Front 1
R33 GTS-t single turbo 908 Dimpled & Slotted Rear 1
Also an update, Scott from RDA is back from his leave, he was back tracking all emails and I've spoken to him, he should send me an updated price list today, and I will inform you all tonight after I got home from work.
Thank's for all your patience.
sorry to nag, just making sure you put me down for the front slotted dimpled for r32 gtst (280mm)
ta,
Greg
edit: don't worry i just checked the first post. sorry. ;)
Edited by R32gts-t
It works out about 75% from the price list I put on the first post.
some are 74.9xxx % some are 76.00xx% so it's workout about 25% discount.
For example R33 gtst front are now $<<price removed pm to GB members only>> per pair excl GST, discounted from the $275 RRP.
by the way all r32 gstt owner need to check if their rear rotors are 266mm or 297mm same like r33 gtst.
about the part numbered 7691, they are 320mm dia right???? i can no find the right information...
I was told for R33 GTR it is not 7691, but 7701 front and 7702 rear. Fronts are 324mm, if you measure it urself using a tape than it's not 100% accurate. but 4mm you're pretty close to the actual size.
thanx can you please put me on 7701 then?? my front ones are 324mm, and i want slotted and dimpled. cheers.
btw, how much would they be?? any way i can see the price?
heslo, yes we are going ahead, will update prices soon, what rotors do you need?
Flash89, yes you can. i will add you to the list ASAP, watch ur pm space soon.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
