Hi all, I have recently brought a 97 r33 series 2 skyline, and the bleed valve was not hooked up, so it was cut out around the 3000 rpm mark. This was approx 3 weeks ago, and I started my car up and noticed a loud chopping sound cuming from my turbo and took it to a proffessional to find out that it was buggerd., my questions are as follows :
Could this turbo be ruined by the bleed valvle not being hooked up?
If i was to replace the turbo i would buy a aftermarket one, What is the next size up that will replace directly where the old one is, and what web site should i go to?
Also What cost am i looking at, and how hard is it to simply replace it?
Thanks In advance....:)
https://www.sau.com.au/forums/topic/131026-my-turbo/
ok thanks for that, but i still need some more info, I took the car when i got it to get a rwc and that found a exhuast leek and when they gave it back to me, they forgot to put the bleed valve back on, and now my turbo is stuffed, was this the cause of this???
https://www.sau.com.au/forums/topic/131026-my-turbo/#findComment-2425555
Depends - if not having a bleed valve, but the vacuum line is still hooked up to the actuator than it'll run standard boost..
if the vacuum hose was NOT attached to the actuator, than it would never open the wastegate and the turbo would boost until your foot backed off the pedal..
Check which it is - 1. does nothing to the turbo.. 2. could cause permanent damage..
https://www.sau.com.au/forums/topic/131026-my-turbo/#findComment-2425806
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
