Jst bought myself a cool R33 GTS25-T. I'm wanting to spead around $5000 - $10000 to a achieve around 250kw - 300Kw at the wheels.
The car is completly stock and i'm wanting to use it on the road as well as one the track.
Could somebody please give me some advise on what I should be changing, what brands I should looking for and also where I can go in Australia, Victoria to tune my car.
If you have the same model as me and also have a similar power output please tell me what ya did.
Cheers :)
Edited by rob123456
  • Replies 91
How bout you start by telling us all what mods the car already has and the reason why you want 250-300kw as there is a massive difference between those figures. Then we can tell ya what ur gonna need...
Edited by FSTR32
as i posted in the other thread
stock gtst
+ front mount $800
+ exhaust $1400
+ ecu $900
+ heavy duty clutch $1200
+ hiflow turbo or gt-rs or gt2835 ($1900 to $2800)
+ airflow meter z32 $300
+ fuel pump $300
+ injectors $600
+ cold air intake $300
+ boost control kit for ecu $300
+ tune $500
+ suspension work $1200
total $10,300
should net you somewhere from 250rwkw to 280rwkw
stock gtst
+ front mount $800
+ exhaust $1400
+ ecu $900
+ fuel pump $300
+ injectors $600
+ tune $500
total $10,300
f*k the AFM off if he's gonna run stand alone ecu
your source is incorrect, there is no way a map sensor can offer more load points than the same map driven by an airflow meter. have a read of http://www.skylinesaustralia.com/forums/in...howtopic=122642
stock gtst
+ front mount $800
+ exhaust $1400
+ ecu $900
+ fuel pump $300
+ injectors $600
+ tune $500
total $10,300
Spot on, and thats without labour costs :)
Although injectors are around $900
Clutch around $1000-$1200
300rwkw doesnt come cheap
250rwkw is far more affordable
Definately stick with the AFM. For those that think they are a restriction or a hinderance, 369rwkw with a Z32 AFM would say otherwise
Hey Paul. Just a quick question. What injectors can i get for $600 and where from.
Car: R33 GTST. :)
Nothing half decent unless your gettin dodgy ones. Most decent ones eg nismo are about 200 bucks each arnt they
try nismo 550's from nengun.com or you can get s15 jdm manual 480cc injectors you should able to get set for around that price.
yeah perhaps my injector price was a bit too low. say $800 for a new of newies then.
gtr injectors arent a direct fit, you need to modify the injector driver or something (cant remember sorry, its in the tutorial section)
Nismo 550cc injectors are not $1200 at all.
I paid $900 landed for 740's back 2 years ago.
"Definately stick with the AFM. For those that think they are a restriction or a hinderance, 369rwkw with a Z32 AFM would say otherwise" Quote by the Wise Nismoid
Is that all? love to see the dyno sheets for that one nismoid
Edited by FSTR32
You have a little to spend. :)
A rough price... As a basis you'll need.
Buy from Japland..
$0330 - Fuel pump
$0700 - Injectors
$1000 - ECU (PowerFC)
$0400 - PFC Boost Kit
$0800 - FMIC Kit
$0050 - Catch Can
$0550 - Clutch
$0330 - AFM
$4160
Now you have to pay some one to fit the parts if unable to do so your self.
Your also going to need a decent preferably 3.5" exhaust, unsure what they are worth.
You also need a turbo. Something along the lines of a GT30.
You 'should' be able to get away with it for 10k. And thats the motor/performance side of things only WITHOUT Labour and Tuning costs. Budget 15k for 300rwkw or 10k for 250 mayybe 270rwkw.
Now you need suspension and brakes.
http://www.nengun.com
and
http://www.gktech.com.au
how about before you offer advice you actually read up and get half a clue what you're talking about before you decide to post up shit.. i'm sorry if i'm being overly harsh but i can't stand people with no idea on a subject yet want to force there oppinion onto others.
Edited by aphid
Better yet, you can even see the video and look at the nice telly screen of it. :)
How good is that eh? Stuff having a sheet, live video recording is a joy.
http://skylinesaustralia.vidiac.com/recent...a697e4dad6e.htm
That also includes a backup run of 358rwkw with a bit less timing.
Safe to say there is nothing wrong with an AFM based car at all.
Um by the way...we still havn't established what the car actually already has???he may have half the stuff that paul 33 has listed so in that case...where could his extra money be better spent? a better turbo perhaps or maybe a bit more tlc to drivetrian or suspension in order to put this "250 - 300kw's" to the ground
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
