The first and singlemost thing I can recommend.
STOP PICKING RANDOM PARTS FROM MID AIR.
do a search, keep searching and keep reading.
have a look at the rb25 turbo upgrade thread.
read what others have done.
search for things like:
2835 by user grepin
2835 by user freebaggin
hiflow by sydneykid
gtrs by user thizzle
  • Replies 91
Grepins is the HKS GT2835ProS, plenum, exh. manifold, cams and a few others bits and pieces. He's really pushed the 2835proS to its limit.
Freebaggin ran a GT3040 with a .63 5bolt style turbine housing and stock style comp cover. Tim Possingham did the specs on the turbo for him some time ago. Back then it was worth close to 3k. The housings weren't simply machined to suit they had more work done to them. I believe it origionally was making 280rwkw on 17psi. Changed comp cover to the .7 ramped boost up and made over 300rwkw. Maybe he can share a little more insight in to what exactly was done to get the power.
Apexi Pfc
Z32 AFM
EBC
Nismo 740cc Injectors
Nismo/tomie Fuel-pump
FMIC
HKS gt3037 Pro S
Full Exhuast
Air Filter
Clutch Upgrade
Tyres Upgrade (this means wider rims, so u can get some bigger tyres on them)
Coilovers (supension upgrade)
Good Brake Pads
-i have most likly forgotten something but this is a good start
hks gt2835 pros is good turbo but if u want 300kw, u need a bigger one
Hello everyone.....
I was flicking through a "high performance imports magazine" and I saw an ad for a high performance engine rebuild kit for a RB25-DET. It consists of:
  • Venolia forged pistons
  • Grant chrome rings
  • R.E.V. I-Beam forged conrods
  • Tomei metal head gasket
  • Genuine Nissan full engine gasket kit
All of this is for $3999
Is all of this stuff at a good price or not???????
cheers :happy:
Dont get Venolia... Get CP or ACL pistons.
Is that's the kit from hi-octane?
Have a look in the RB25DET turbo upgrade thead for turbo selection for a few ideas 2530 is to small for what you want to do.
Id recomend a HKS GTPROS turbo kit comes with everything needed and bolts onto the stock manifold, it will be good for arround 270rwkw with room for a little more.
At levels above 270rwkw you may run into reliability problems if you drive the car hard, plus the you will need a large turbo whcih means more lag.
For 300rwkw+ a rebuilt engine with a 3 litre bottom end would be a good option the extra capacity will give you less lag and power can be made lower in the rev range which means less stress on valve train parts.
If you go the HKS PRO-S route you will need the parts others have already stated
Injectors
- S15 JDM manual type, nismo 550cc or 740cc
Fuel Pump
- new bosche pump 040 or 044, tomei or nismo direct fit
Air Flow meter
- Z32 airflow meter will be plenty big enough
ECU
- Power FC with Hand Controller and boost controller option
Clutch
-Exeedy seem to be a popular choice
Cams optional but recomended
-Tomei pon cams
Intercooler
- might want to go for a JDM type, not sure how the cheap hybrid and hybrid copy coolers will go at this power level.
Exhaust
- 3 to 3.5 inch exhaust from turbo back with highflow cat (the bigger the better)
As for pricing it can vary shop around www.nengun.com has good prices for your cams, turbos, ECU and intercoolers.
Search the for sale section on this forum heaps of specail offers for exhausts, intercoolers, etc.
If you shop arround you may be able to get away with spending less than $10,000
cheers
Better yet, you can even see the video and look at the nice telly screen of it. :O
How good is that eh? Stuff having a sheet, live video recording is a joy.
http://skylinesaustralia.vidiac.com/recent...a697e4dad6e.htm
That also includes a backup run of 358rwkw with a bit less timing.
Safe to say there is nothing wrong with an AFM based car at all.
OMG...thats an awesome vid nismoid..
I assume thats your car ???
Can you PM me some details on the setup ?
Looks to be a lowmount with an external gate ?
hehe those manifolds look suspiciously like GTS-R ones :D
Suspicion would proove correct :O
I actually own a GTS-R... and it still retained some of the Nismo gear from the factory, the GTS-R manifolds are awesome.
Good mate of mine now owns the manifold, they are worth a pretty penny lemme tell you.
PM sent :D
Amazing how the peanut gallery went quiet once the video came out hehehe.
My tuner has expirience with both MAF and MAP applications for the RB's.
If he tells me in his expertise that the AFM is not a restriction, then i'll believe him based on his testing and applications.
I trusted his judgement and made more power than anyone else said was possible at the time.
When a PowerFC is $900, and the AFM $250-$300 thats $1200.
Would i be right in saying a MAP based ECU is a little more expensive in most cases?
The closest that comes to mind is $1400 at the very least. I think more decent are wire-in at a $2000+ cost
So cost for cost, the AFM + PowerFC Combo will works out cheaper.
As stated he is in Vic, and *most* tuners will prefer to use a PowerFC down here as opposed to anything else.
Nar MAP based ECU isn't always more expensive.
Some people are happy enough with a MAP based tune also, even if technically its not as responsive.
$1000 for Microtech (with x4 ign module) on my SR20 - $300 for tune. Self installed. total cost $1300.
$1200 for PowerFC + the tuner said he would charge a tad more for PowerFC tune. Total would have been $1600.
I'll probably go PowerFC on my skyline though, two more injectors and two more coils to wire might scare me off the microtech install again. Takes take a few hours to wire an ecu in.
Suspicion would proove correct :ninja:
PM sent :laugh:
Quiet??? did somebody say quiet? haha
IMO
seen better...
spoke too soon nismoid...
oh yeh by the way...i think the reason i went quiet after u brought that video out was cos YOU BARRED ME cos ya couldn't hack it and ya had a cry...bit hard to speak up when ur barred ey!
My 2 cents
lmao... yer right..
And were all going to believe that. lmao.
:O
Hey you know whats funny...besides ur name...if you mix the letters of 'lmao' you get LAMO!!!! something for you to think about :D
I believe Nismoid ran the stock gtr bov's.
A GTR BOV >_<
Just one... not the both of them, you can see it in the vid... it is even plumb-back :sorcerer:
Was actually talking about it today, it worked so well with just the one even with that amount of boost given.
Definately worked beyond expectation without using both of the BOVs like on a GTR.
There was a tad of flutter on 24psi.
However when using under 20psi it was actually quite ok and there wasnt a hint of flutter or anything so yeah. Worked well IMO.
  • 1 year later...
as i posted in the other thread
stock gtst
+ front mount $800
+ exhaust $1400
+ ecu $900
+ heavy duty clutch $1200
+ hiflow turbo or gt-rs or gt2835 ($1900 to $2800)
+ airflow meter z32 $300
+ fuel pump $300
+ injectors $600
+ cold air intake $300
+ boost control kit for ecu $300
+ tune $500
+ suspension work $1200
total $10,300
should net you somewhere from 250rwkw to 280rwkw
ive got most of this to go on my car except for
+ injectors $600
so at the moment ive got 182 or 84 rwkw now on low boost 5psi splitfires made me gain a few kw too
clutch no need ive got a auto but have stage2 shift kit but have to change to a manual-auto because ove shift point issues with aftermarket computer should i see around the same figure ps im in the process off getting nismo 555cc injectors for it is that ok?
Edited by R334door(s2)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
