The first and singlemost thing I can recommend.
STOP PICKING RANDOM PARTS FROM MID AIR.
do a search, keep searching and keep reading.
have a look at the rb25 turbo upgrade thread.
read what others have done.
search for things like:
2835 by user grepin
2835 by user freebaggin
hiflow by sydneykid
gtrs by user thizzle
  • Replies 91
Grepins is the HKS GT2835ProS, plenum, exh. manifold, cams and a few others bits and pieces. He's really pushed the 2835proS to its limit.
Freebaggin ran a GT3040 with a .63 5bolt style turbine housing and stock style comp cover. Tim Possingham did the specs on the turbo for him some time ago. Back then it was worth close to 3k. The housings weren't simply machined to suit they had more work done to them. I believe it origionally was making 280rwkw on 17psi. Changed comp cover to the .7 ramped boost up and made over 300rwkw. Maybe he can share a little more insight in to what exactly was done to get the power.
Apexi Pfc
Z32 AFM
EBC
Nismo 740cc Injectors
Nismo/tomie Fuel-pump
FMIC
HKS gt3037 Pro S
Full Exhuast
Air Filter
Clutch Upgrade
Tyres Upgrade (this means wider rims, so u can get some bigger tyres on them)
Coilovers (supension upgrade)
Good Brake Pads
-i have most likly forgotten something but this is a good start
hks gt2835 pros is good turbo but if u want 300kw, u need a bigger one
Hello everyone.....
I was flicking through a "high performance imports magazine" and I saw an ad for a high performance engine rebuild kit for a RB25-DET. It consists of:
  • Venolia forged pistons
  • Grant chrome rings
  • R.E.V. I-Beam forged conrods
  • Tomei metal head gasket
  • Genuine Nissan full engine gasket kit
All of this is for $3999
Is all of this stuff at a good price or not???????
cheers :happy:
Dont get Venolia... Get CP or ACL pistons.
Is that's the kit from hi-octane?
Have a look in the RB25DET turbo upgrade thead for turbo selection for a few ideas 2530 is to small for what you want to do.
Id recomend a HKS GTPROS turbo kit comes with everything needed and bolts onto the stock manifold, it will be good for arround 270rwkw with room for a little more.
At levels above 270rwkw you may run into reliability problems if you drive the car hard, plus the you will need a large turbo whcih means more lag.
For 300rwkw+ a rebuilt engine with a 3 litre bottom end would be a good option the extra capacity will give you less lag and power can be made lower in the rev range which means less stress on valve train parts.
If you go the HKS PRO-S route you will need the parts others have already stated
Injectors
- S15 JDM manual type, nismo 550cc or 740cc
Fuel Pump
- new bosche pump 040 or 044, tomei or nismo direct fit
Air Flow meter
- Z32 airflow meter will be plenty big enough
ECU
- Power FC with Hand Controller and boost controller option
Clutch
-Exeedy seem to be a popular choice
Cams optional but recomended
-Tomei pon cams
Intercooler
- might want to go for a JDM type, not sure how the cheap hybrid and hybrid copy coolers will go at this power level.
Exhaust
- 3 to 3.5 inch exhaust from turbo back with highflow cat (the bigger the better)
As for pricing it can vary shop around www.nengun.com has good prices for your cams, turbos, ECU and intercoolers.
Search the for sale section on this forum heaps of specail offers for exhausts, intercoolers, etc.
If you shop arround you may be able to get away with spending less than $10,000
cheers
Better yet, you can even see the video and look at the nice telly screen of it. :O
How good is that eh? Stuff having a sheet, live video recording is a joy.
http://skylinesaustralia.vidiac.com/recent...a697e4dad6e.htm
That also includes a backup run of 358rwkw with a bit less timing.
Safe to say there is nothing wrong with an AFM based car at all.
OMG...thats an awesome vid nismoid..
I assume thats your car ???
Can you PM me some details on the setup ?
Looks to be a lowmount with an external gate ?
hehe those manifolds look suspiciously like GTS-R ones :D
Suspicion would proove correct :O
I actually own a GTS-R... and it still retained some of the Nismo gear from the factory, the GTS-R manifolds are awesome.
Good mate of mine now owns the manifold, they are worth a pretty penny lemme tell you.
PM sent :D
Amazing how the peanut gallery went quiet once the video came out hehehe.
My tuner has expirience with both MAF and MAP applications for the RB's.
If he tells me in his expertise that the AFM is not a restriction, then i'll believe him based on his testing and applications.
I trusted his judgement and made more power than anyone else said was possible at the time.
When a PowerFC is $900, and the AFM $250-$300 thats $1200.
Would i be right in saying a MAP based ECU is a little more expensive in most cases?
The closest that comes to mind is $1400 at the very least. I think more decent are wire-in at a $2000+ cost
So cost for cost, the AFM + PowerFC Combo will works out cheaper.
As stated he is in Vic, and *most* tuners will prefer to use a PowerFC down here as opposed to anything else.
Nar MAP based ECU isn't always more expensive.
Some people are happy enough with a MAP based tune also, even if technically its not as responsive.
$1000 for Microtech (with x4 ign module) on my SR20 - $300 for tune. Self installed. total cost $1300.
$1200 for PowerFC + the tuner said he would charge a tad more for PowerFC tune. Total would have been $1600.
I'll probably go PowerFC on my skyline though, two more injectors and two more coils to wire might scare me off the microtech install again. Takes take a few hours to wire an ecu in.
Suspicion would proove correct :ninja:
PM sent :laugh:
Quiet??? did somebody say quiet? haha
IMO
seen better...
spoke too soon nismoid...
oh yeh by the way...i think the reason i went quiet after u brought that video out was cos YOU BARRED ME cos ya couldn't hack it and ya had a cry...bit hard to speak up when ur barred ey!
My 2 cents
lmao... yer right..
And were all going to believe that. lmao.
:O
Hey you know whats funny...besides ur name...if you mix the letters of 'lmao' you get LAMO!!!! something for you to think about :D
I believe Nismoid ran the stock gtr bov's.
A GTR BOV >_<
Just one... not the both of them, you can see it in the vid... it is even plumb-back :sorcerer:
Was actually talking about it today, it worked so well with just the one even with that amount of boost given.
Definately worked beyond expectation without using both of the BOVs like on a GTR.
There was a tad of flutter on 24psi.
However when using under 20psi it was actually quite ok and there wasnt a hint of flutter or anything so yeah. Worked well IMO.
  • 1 year later...
as i posted in the other thread
stock gtst
+ front mount $800
+ exhaust $1400
+ ecu $900
+ heavy duty clutch $1200
+ hiflow turbo or gt-rs or gt2835 ($1900 to $2800)
+ airflow meter z32 $300
+ fuel pump $300
+ injectors $600
+ cold air intake $300
+ boost control kit for ecu $300
+ tune $500
+ suspension work $1200
total $10,300
should net you somewhere from 250rwkw to 280rwkw
ive got most of this to go on my car except for
+ injectors $600
so at the moment ive got 182 or 84 rwkw now on low boost 5psi splitfires made me gain a few kw too
clutch no need ive got a auto but have stage2 shift kit but have to change to a manual-auto because ove shift point issues with aftermarket computer should i see around the same figure ps im in the process off getting nismo 555cc injectors for it is that ok?
Edited by R334door(s2)
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
