What should he get for his bday??
39 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Happy bday damo :P whatever you get yourself i might buy your old shit to put on my car, the cooler is still going strong lol
My opinion - Chrome spinners FTW !! every black man needs chrome spinners right??
https://www.sau.com.au/forums/topic/131339-happy-bday-damo/#findComment-2430259
Happy Birthday Damo. I almost voted "A ROOT" but it seems everybody has that one covered for ya. Plus I'm sure with your manly physique you would have no problems with "pulling a root".
Instead, I voted for suspension so you can get your "slow 34" out on the track next year!!!! :O
https://www.sau.com.au/forums/topic/131339-happy-bday-damo/#findComment-2430633
Happy birthday mate!
The poll should realy read what should Damo STEAL for his birtday...as black men buy nothing
I say steal suspension first HKS Hypermax 2 is cheap and so far it has been pretty good for me!
Just dont steal mine :O
https://www.sau.com.au/forums/topic/131339-happy-bday-damo/#findComment-2430790
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
