Hi all, i have a pair of front rotors for sale, they are used and in good condition. These are Apexi GT 2-piece rotors, each weigh about 6.5kg, lighter than normal rotors, comes with the center hats n bolts attached, ready to be put on. Both rotors are slotted. These came off my GTR32. Location is Brisbane and asking price is $300. Pls PM me, call/sms 0433553356, email [email protected] for further enquiries, info & etc.
post-23256-1156249836.jpgpost-23256-1156249857.jpgpost-23256-1156249886.jpgpost-23256-1156249908.jpgpost-23256-1156249953.jpg
Edited by J-Boy
Frankxy: These are 296x32 rotors, i doubt there's any reason at all that u would wanna fit them on a GTR33... :rolleyes:
benigno: I am not too sure if type M calipers would fit, but i think it should be fine, basically if the type M calipers used the same brake pads as a standard GTR32 caliper im pretty sure it would fit fine.
Angry: Well im not too sure about the costs of replacement rotors as i have not checked the prices of that out...it also depends on which kind of rotors u look at to use as replacement, a good guideline might be the prices of project mu's SCR range of rotors.
tacker: Yes hats are aluminium, these are about at least 2kg lighter than standard 1-piece rotors.
  • 4 years later...
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
