Hrmm i thought they were drop ins... cheers for assuring ^_^ RWD will be crazy... Think of the torque O_O.
Gonna turn my R34 non turbo into a project soon... Response monster... Mines Skyline is one of the hardest revving cars ive seen...
work? yes
good idea? no
cost effective? no
safe? probably not
if you drop the rb26 into your n/a gtt then you need to upgrade the brakes, clutch, tyres, suspension and whatever else is attached
just sell it and buy a gtr
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
