As the title states.......curious to know if they are avail or not and when they will be.....no one seems to be making copies of them.....damn sexy wheels
Edited by lingeringsoul
  • Replies 44
pretty sure it won't fit my car.
hope someone starts selling these 5 spoke BeeR copies soon, they are just too nice to ignore
You may already know im not sure, but Otomoto are selling the real thing. Going for 500 per wheel for 18s, have a squizz at http://www.otomoto.com.au/beer.htm if youre keen. BTW i have zero association with this company just saw them advertising in HPI (yes i know he owns the store and is the editor of the magazine too!!)
as much I love original products, money is still an issue for me. Guess i'll get them when I get a bettter paying job.
BeeR copies gonna be the the new implus now? Oh noes
hope not........i think the impuls dish look is still popular, heck even I was tempted to get some......but i'll be wanting some BeeR wheels in the very distant future.
why do you need copies? they are cheap as already. they cost around the same as a set of starcorps or whatever. $500 a pop is as cheap as your ever going to get for an 18 inch wheel that doesn't look like arse.
pretty sure the GTR size ones are 18X9.5. of course the Bee-R/uras/d-tek/driftek/whatever are all basically copies of the rays nismo LMGT4s. They are all cast, hence the low price.
edit: what site are you looking at stanski? in 18inch they ONLY come in 9.5inch.
B5 racing wheels
Bee Racing’s own five-spoke wheel as used on the Bee Racing D1 car. Available in two sizes, with 5x114.3mm PCD only. Silver, bronze, white and super-chrome are available to order. Call for availability as various colours are kept in stock.
17x9 +25mm offset $479 each
18x9.5 +25mm offset $499 each
18x9.5 +38mm offset $499 each
i too am a fan of the Bee-R wheels, but they are WAAAYYY to wide (at the front) for me, so unless they make different sizes, a copy or getting them fixed and narrowed would be the only option
Problem (like someone has mentioned) is that the Bee-Rs are built for GTRs only so there is no way the 17x9 (+25) will fit under the front guards of a GTS-t.
However, the Bee-R copies come in smaller rim sizes (17") with GTS friendly offset.
That's the main reason people go for the copies.
Anyway here's a Aussie seller where you can get the copies (D-Spec brand):
http://www.bt-revolution.com/D-SPEC%20Page.htm
As you can see they come in 17x8.0" +30 which suit GTSs (and 200SXs etc)
However if you think the D-Spec brand is not good quality, you can also get Bee-R copies made by the trusted JDM brand URAS:
http://www.bt-revolution.com/URAS%20Wheels.htm
Funnily enough they are the same price as D-Spec!
who'd buy r34 gtr wheels when you could buy those beeR for 500 each
finally the r34 gtr wheels might be priced what they are actually worth. that is, around 1000$
you are living in a fantasy land. Bee-r rims are a CAST wheel. genuine 34 GTR wheels are FORGED. That alone accounts for a massive difference in price. Plus I am not 100% sure where the Bee-R wheels are made but the genuine 34 wheels are definately made in japan. They are standard equipment on a $100K+ supercar. Bee-r wheels are a relatively cheap, aftermarket wheel. there is no real comparison.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
