Here's a quick rundown of the day:
NismoR34 - R34 GTT with pod, cat back and boost
182.0 rwkw @ 7100 rpm
Jet-33 - R33 GTStApexi S-AFC, Blitz Access ECU, Blitz BOV, 3" zorst, POD, Turbosmart boost controller @ 14psi peak holds 11 psi
179.9 rwkw @ 6900 rpm
RUS - R33 GTSt Mods ???
183.2 rwkw @ 6800 rpm
TUFR33
MUCK
riggaP
Adzmax - R33 GTSt Mods ??
164.9 rwkw @ 6700 rpm
INASNT - 400rwkw Supra, apprently INASNT was 'having us on' and couldn't deliver :D
DJ_L3ThAL - R33 GTSt, SAFCII, Boost, leaking BOV (now fixed), possible faulty coil pack also
162.4 rwkw @ 7000 rpm
Jamezilla
Adz - My old R32, unfortunately he slept in :P
Matty - R32 GTSt, who also 'slept in'
R31Nismoid - Unfortunately when fitting a boost controller I discovered the R31 had a faulty fuel pump which will be replaced shortly.... expect some big numbers soon
Al - R33 GTST, Wolf 3D ECU, 12 psi boost
172.4 rwkw @ 6400 rpm
R32PWR - Mental R32 GTSt RB27 with twin HKS 2835R's, unfortunately during "testing" on the previous thursday night full boost in second managed to snap the RHS axle... But beware....
Ronin 09
RedlineGTR
Meggala - R32 GTST, Pod, Zorst, 14 psi Boost, Dr_Drift ECU
148.0 rwkw @ 6800 rpm
Ben from BMT - 180SX, SR20, Dr_Drift ECU (not tuned yet), 17 psi boost peak holding 12 psi, FMIC, zorst, filter
155.3 rwkw @ 6000 rpm
Mutex - Stock as a Rock R34 GTT
161.1 rwkw @ 7000 rpm
https://www.sau.com.au/forums/topic/13156-dyno-results-29303/
ooooooo i c.
1fitty! hmmmm.. damn it i want an extra 8rwkw!
can u ask benny it will be for stainless 3" dump and front pipe?
im thinking of not bothering with the cooler just yet and get these bits done first.
Thanks again Doc!
One thing has got me curious though: did the guys keep turning off the TCS after each restart of engine?
TCS always comes back on after ignition / engine shutdown!
Perhaps this explains why increased boost and also using your BV didnt make a difference?
I only turned off TCS the first time...
Originally posted by nismoR34
Thanks again Doc!
Don't really know actually?? I'm pretty sure they didn't turn it off after restart.... hmmmm that will have to be an experiment for my new dyno??
Sounds like a plan to me :(
What brand dyno is it? Locality [near Essendon or ?]?
I am pretty keen - though I am not expecting to get much more than 182 in current form... I will probably wait until after I have done some mods. Looking at finishing off exhaust soon.
It's a Dyno Logic, I've researched thoroughly and believe this is a much better product, and has many more features than the more common Dyno Dynamics. The new premesis will be in Heidelburg.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
