Just wondering if you guys know if the stock 17" x 9" GTR wheels with 245/45/R17 will fit on a S14 200SX? My stocko wheels are the Nissan 16" alloys. They have 205/55/R16 rubber on them. Im pretty sure the offsets should be alrite, just wanna know if theyre too wide. Any help or links to this topic would be appreciated. Cheers, Paul
Edited by Paul B
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/
the only reason i know they fit is because there is a someone at heasman steering in sydney with a white s14 r33 gtr wheels. lowered and looks good.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2437350
17x9 on my S14 needs to be +20 at the front to clear the coilovers.
On the rear 245/40R18x9+22 fit without any spacers
This is what an S14 (not mine) looks like with +30 offset, 25mm spacers all round. = +5 offset.
Only a fender roll is required to fit this. Tyres are 215/40 front, 215/45 rear.
Wheels are stock R33 GT-R wheels which are 17x9, the narrow tyres allow the nicer fitment
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2442274
^^^ it's not that they will sit in, it's that they will hit the strut/spring, i have them on my s13, i have 3omm spacers all round, i could probably get away with no spacer on the rear but definatley needed on the front.
225 is about as wide as i can go with the spacers fitted, 215's may fit without the spacers... great looking wheels you should put a pic up.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2444122
They just bolted onto my old 200SX fitted with 235/45/17 with 2.5 degrees of camber.
I only had OEM style Nismo replacment struts and they cleared the shock body and spring seat fine.
Looked pretty understanded on white too.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2460826
did u have spacers fitted on yours???
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2461118
Hey there,
I have a set i am selling with 245/45/17 tyres Hankook Ventus 104's 95% Tread.
Look in the parts section.........
They do look good on a s14 I have to admit.
Although i think they would look better with rolled or flared guards.
Cheers
Tekin
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2461375
frankxiyu pm'd me, but for everyone else - no spacers were fitted to mine, but they did rub the plastic inner guard a little,but nothing a stanley knife couldn't fix.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2463634
just an update for the information,
the R33 GTR wheels which have 245 tyres went on the S14A today with NO spacers, and we did not roll the guards....stock suspension, which means once coilovers are done, even widers tyres can go on....
it is doable, and the car looks awesome....problem solved.
https://www.sau.com.au/forums/topic/131590-r33-gtr-wheels/#findComment-2502142
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
