Hi there, I maybe thinking of changing my brake setup soon and if I am not mistaken R34 GTT brakes are 310mm and the R33 GTS-T brakes are 296mm? This also means that the the caliper on the R34 is bigger? Is it simply wider? Longer? Or both?
Reason asking is because I've got a mate with an R33 GTS-T 4-door (does it matter if it was coupe or 4 door) and his interested in my brakes. I won't mind using his brakes temporarily while I look for new brakes. But yes the main question is: are the calipers, rotors and pads interchangable between an R34 GTT and R33 GTST?
Thanks,
Andy
  • 3 weeks later...
Hey mate, was doing a bit of looking. It appears the 34 caliper is virtually the same the only difference in size is in the mounting lugs to accomodate the larger disk...
See here
http://www.skylinesaustralia.com/forums/in...howtopic=121668
