  • Replies 40
yeah its been a three week labour funkymonkey haha.
yes ant she is now mine!! i am so going to either lose my license or kill myself she is actually faster than the skyline.
Great stuff Niz......I know how capable they are....I was up against one at a deca day in Vic...only power mods were intake and exhaust but it had a crap load of suspension work.....even my 200rwkw gtst was humbled by it (not by much but even so).
Enjoy it and I hope to see you at a track or skidpan soon :huh:
  • 3 weeks later...
Nice car niz, I have been sorely missing a turbo car and have been thinking about what to get as my next ride. A mate bought one of these a yellow limited ed one and I went for a drive in it the other day (basic modes, exhauast, pod filter, better suspension) and I was amazed at the low down torque and overall acceleration... i might have to look at one of these :)
nah jezz decided it wasnt for her .....its gone to a new home in rockingham so maybe some of the RICE crew might see it around .... but i doubt it. Its this guys first import - had VK statesmens and stuff like that before. In the end it sold for $14.5K
I had a cry! then i sat in my new project :rolleyes:
yeah but when importers are selling them for about $8K and other people with the same configuration are selling them for $15K .... not much of a choice. Unfortunately a vehicle is only worth what someone is willing to pay for it ...... plus it gets paulie off my back about selling it.
Admittingly my R33 wasn't exactly in perfect - there was a little bit of race tape on there where the corner of the front spoiler had been ripped and a trolley ding in the side etc.
Dan Im not going to argue with that its becoming scary in fact!!
Maybe i should even get a job as a carsalesperson :)
I've started even going off in threads (not these forums) "Should I by this car" it's like why the hell do you need a thread to ask every john, dick and harry should you buy a car or not - we aint going to be driving it, we aint going to be paying for it ..... if you like it and can afford it then the only person left ot give it the okay is an mechanic. Geez .... hahaha maybe that should go in the "what really grinds my gears thread" people that have to bring a committee or consult a committee of people before making a decision that at the end of the day will only effect them.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
