At subbies a fair bit... was at last Transmission with Zany... Was awesome!
You dont see many younguns... if you do you kick em while they are down... :D
Saw Zany(opening track was Jump around by house of pain. COOOOLL) and DBD at Melbourne Transmission whilst on holidays down there...First time out in Melbourne but man the scene is so different down there. 2 thousand people all doing the Melbourne shuffle in unison. Bit ghey if you ask me.
hmmm, 12 yr old candy wanks gurning and letting thier glow stix fly, throw em back ^^
many many memories of these lil smack tard wanks falling over em selves in skanky shitholes.... yea kinda got over it a few years ago...
hmmm, repetitive sets... over an over hearing some raelly crap mixing and kiddy scratches.... yea phully sik the all night dance party massive... hahahahaha
some have got talent admitedly, some need to learn how to read music,
push your own tracks and il listen aye, re-hashing 10-15yr old tracks gets old.
find me an event with a $15-$20 cover charge that serves alcohol AND has some decent stuff to listen to, breaks, lots of diff house less the 70's throwbacks and hmmmmm yea maybe even a few drum roles an i'd turn up.
lets see...$80+ just isnt worth more often than not... but thas just me eh
to those who went to Magic City
when Dark by Design was on ....u know how he was standing on the top of the speakers stacked up and he was going crazy....the speakers started to wobble and i full thought he was gonna fall off!!!!
...but he quickly jumped off before he lost his balance
These are NOT raves... just techno/trance parties.
A rave, for starters, is by invitation only and where it's held is usually a secret till the night.
but.... carry on.
Damn straight.
Marsss, do you ever host any latino "raves" ?
but.... carry on.
http://en.wikipedia.org/wiki/Rave
A rave (sometimes referred to as a rave party) is an all-night dance event where DJs and other performers play electronic dance music and rave music.
Dude...read the rest of that link you posted.
As law enforcement agencies increasingly began paying attention to raves, concealing a party's location became important to an event's success. To that end, event organizers sometimes either promoted events solely by word-of-mouth, or would only reveal the date and location of the event to subscribers of an electronic mailing list or via voicemail. Some even went so far as to provide a series of clues or map checkpoints that ultimately led to the location of the rave
Yeah i call these ether dance or trance parties. I love them but know they aren't raves.
Someone asked me if i went to any raves this year and i said no. then my friend said yeah you have, you went to transmission. i just laughed at him and said thats not a rave it's just a dance party.
Some people like calling them that i think so it sounds cooler or something i guess.
Had my last one last weekend..
Thats my lil boy..
Dj Bangers.. hes all grown up now :) *sigh* lol.. pretty darn good set too.. it was going off..
haha yeah..matty sims besides you..so tipy :):P
where was this last time i saw simsy was on ice getting smashed by me ahah
if you see him tell alber said hi
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
