Hey guys. I am having an issue with my GTR33 and I just cant seem to figure it out! Here is the info:
I have a 96 GTR33 and my rear end shakes at speeds exceeding 100kmph. Now it does this in all different gears not just gear 3 or gear 4. However, I do not feel the problem at all with speeds less than 100kmph. When the rear end shakes it feels like I hit a wet spot and lost traction for a second and then regained traction and instant later. It is not a violent shake, nor does it last long, it also happens intermittently. It happens every once in a while. Also it often happens when I am not in boost at all and I am also cruising at a constant speed. I am not necessarily stepping heavy onto the gas. I mean it feels EXACTLY like my rear wheels hit a water spot and slid a bit. Also if I recall correctly it tends to shake to the right. Any ideas on what my issue may be? I am going to the shop tomorrow for a tune up and would like to have something to tell them to check out. Thanks guys.
-Sayajin
https://www.sau.com.au/forums/topic/132081-shaking-rear-end-on-gtr33/
Well came back from the shop today and it appears that my HICAS motor is dead. It SEEMS that the rest of the system works however. So now I am in the market looking for a HICAS motor. (You know the little black thing in the back under the car in the middle of the rear axle?) If anyone has one, or knows where I can get one decently priced any help would be greatly appreciated! Thanks a lot.
Also
I have indeed heard from quite a number of people that it would probably be best to just eliminate the HICAS system all together. However, I would really like to get it back up and running first. I at least want to experience the system and then make an informed decision for myself on wither I want to eliminate it or not.
Especially with the problem being something as simple as just the motor. That is just a few bolts and then im done. So while I do appreciate the opinion to remove the system all together, I would appreciate it even more if someone could either point me to where I can get a new HICAS motor or tell me that they had one available (im sure some of you do since you have locked your systems). Thanks a lot for the help!
-Sayajin
was about to say HICAS before i read your post, woohoo 1 point for me.
put up a WTB thread, plenty of people have removed HICAS from their car, so you should get the motor cheap.... GTRgeoff is one of them, maybe you can pm him.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
