Ok guys it took a straight week to tune my car but i am about confident that i have reached my goal of about 600HP. (on my gtech i push in about 520HP but correctingthis value for wind resistance and rolling resistance it will ammount to about 600 WHP) enough of that, there is a little problem i experience when the T04Z is comming on boost, according to my AEM UEGO wideband datalog my AFR is steady at 14.3 idle and the moment i hit boost the fuel curve comes down to about 12.1. but as the boost builds when im changing gears and let of the throttle i get a huge backfire about 1.4m long. i got fined for frying the lens on a policecar that was onfurtunate to drive behind. this is realy starting to irritate cuz when i pick up my GF the whole neighborhood knows im comming cuz of the huge cannon i have trailing behind me. what can there be done to resolve this problem. should i lean the tune out a bit more to about 12.5 or should this be the way things are, and is this going to hurt my turbo or the exhaust side of the head in any way? the flame does not start in the muffler it starts just after.
https://www.sau.com.au/forums/topic/132186-got-fined/
do you have an Atmo BOV?
if so, ditch it and get a plumb-back... will solve alot of your problems... sounds like it is overfuelling on gearchange, which an Atmo BOV will cause... this is due to it 'dumping' already metered air out of the system... the computer continues to pump in enough fuel to compensate for this already-metered air (which is no longer there) hence it runs rich.
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2447559
i dare say that he isn't running the stock ecu, so an atmo bov shouldn't change it much.
how lean is your low load tune? that may be the problem. if your low load afr's are too rich then when you lift of it is dumping in too much fuel.
also i'd say your cat is well and truly gone.
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2447732
first of all i live in a country where we dont know what cats are ( at least the cops dont) hence i run a 3.5 inch full turboback exhaust (no restrictions just turbo and a pipe with a resonator in the middle and a muffler in the end). i run a PFC and after the advice of R31Nismoid i am still utilizing the stock GTR BOV's instead of going to the HKS SSQV (very pleased with my choice the dont leak shit quite surprising for a stock item) but i have vented the BOV as i dindt have time to make the piping to recirculate it. is is good if the flame is a bright blue colour?? cuz yesterday at a stopsign (around 12pm) some dude in a honda S2K tought he had a chance so the dude starts reving his engine. im at the end of my run in period (still have about 100 miles to go) so thought what the hell, revved it up to 9000 and dumped the clutch, lit up all 4 and when i changed in to second the only thing i saw in my rear view was a bright blue flame (thank god it doesnt burn the body of the car) but when i change from second to third the flame becomes a mis between yellow and blue and when hitting 4th its nearly complete yellow and 5th its yellow. so what i thing its farly lean on low load and when reaching higher load it richens up which is a good sign but the backfire bothers me
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2450940
ill provide the pics of the whole buil on a website i am constructing at the moment. but i am very busy at work lately and being a new dad to a set of twins its very hard to get some work done at home. the whole tuning process has video, pictures i even have a video where i run against a friend of mine with the same car he only has a HKS stroker and a T88H 34D turbo on its and makes about 800-900 HP but i did it to show him that he cant drive his car. and if i get this flamage with a cat isnt there a huge chance that i burn the internals of the cat to bits?? the next step for my car is work on the exterior and interior a bit cuz the car is fully stock on the outside. i have sent my valve & coil cover to be powdercoated and the car is going into the paint booth one of these days
Edited by Faid
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2451598
Vent the BOV’s back into the turbo inlet system and I bet the problem goes away. Just in case you don’t know what is happening;
1. The AFM’s measure the incoming air flow
2. The ECU squirts in the amount of fuel necessary to match that amount of air
3. The BOV’s vent the air after the AFM;s have measured it
4. So you get a whole heap of fuel with not enough air for it to be burnt in the combustion process.
5. Hence some unburnt fuel heads out of the engine into the exhaust system
6. That unburnt fuel either ignites straight away and gives a long slow reddish flame out the pipe (like a V8 Supercar on overrun)
7. Or, it sits in the exhaust until you put you foot back on the throttle and gives a nice bright ignition flash that is blue to white in colour.
Recycle the BOV’s and the problem will go away.
:) cheers :laugh:
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2452497
hell yeah. i know what i am doing for my next party trick he he. putting my hks ssq back on. COol oh wait i have a cat, damn it. Shame about the fine. lucky you dont live in the city. i dont know about anywhere else but in perth, something like that will grant them ability to pull your car of the road for a month.
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2452919
Or you could just do a keybanger :blink:. With the mircotech i had you had to turn off the ignition to reset the
display, and kabam! Great for surrounding motorists
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2452966
dont live in the city, i dont even live in your country. i live far away from australia you can say on the other side of the planet. I live in the 3rd world. here we dont know nothing about emissions testing and so on and so forth. in my country when you go to the police to get your car cleared they only test your brakes :P . ok ive recirculated my bovs. (pain in the ass to take the IC off. but the backfire stopped. thanks
https://www.sau.com.au/forums/topic/132186-got-fined/#findComment-2454015
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
