  • Replies 43
no offense guys, but i can't be believe you're in DOUBT about the validity of this listing! Allblitz is being sarcastic through his teeth :O
buy now price of $7700 AUD?? hahahahahahh, doesn't even warrant a "maybe" thought at all... it's a dead set scam...
lol well said
and even if it was $7700 + import costs...where's the problem with that? lol
It's a dead set scam. For starters the guy became a member on ebay yesterday, and has 0 feedback, so has never made a sale.
Also look at the item location, Item location: SYDNEY, Australian Capital Territory, Australia <<<<<<<<<<<<<<<<Prob never even been to Australia before...
Check out how his got the reply box on the page. Why wouldnt he just simply let the bidder go to "Ask seller a question"
Transmission: Automatic <<<<<<<<<<< in pics its manual n i didnt know they make gtr in auto...
Number of Previous Owners: 0 <<<<<<<< exactly right cause it dont exist...
Dunno bout you guys but i wouldnt spend $7,723 on a sus auction on ebay...
Edited by MR R34
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
