I have recently purchased a 99 R34 GTR. Now I want to make it the best all around performance car I can. I want it's HP numbers between 500 to 600 (373 to 448 Kw) to the wheels. I plan on dumping a ton of money into it and I figured since they are actually legal in Australia that you guys would have a ton of experience on them.
Thank you in advanced
https://www.sau.com.au/forums/topic/132343-american-needs-help-with-r34-gtr/
n1....why not go for a nismo gt block? Are they not supposed to be the ducks nuts of the rb26 blocks?
80g...damnit, why spend that on a road car....build a track car 80g ontop of what you have would be awesome so long as you do the work yourself cause thats alot of parts you can get.
Also 600hp at all 4 wheels is alot of power, probably too much for a street. I dont know what the loss is for 4wheel drive but i would say at least 100hp minimum so thats like 700ponies(523 4wkw) at the fly, maybe more!
Edited by r33_racer
I wasn't sure if I could find a Nismo GT block.
As for the money that would cover every aspect of the car...Suspension, new interior and body styling new paint...But mostly will go to engine.
As for the 6oo HP to the wheel that is my max, but maybe 560 to 580hp would be fun
And from people I have asked with a manual AWD you lose 80hp
Harley,
You really need to take into account what you want from your car. Most GTR's (here anyway) are used as daily drivers. I like to use mine more for track work rather than drags or dyno. I have it set up so I get reasonably early power, but not MONSTER power which would see me with more lag down low. The highger your horsepower requirements (generally) the higher your lag. I have mine built firstly for reliability and secondly for performance. Forged internals would be mandatory for reliability and power. Also if you are going near the track, get a race sump - not a street sump which most of the performance houses sell.
I still use a single plate clutch which is a delight to drive with and has held up extremely well on the track.
I can't stress enough to work out what it is you really want to do with the car before you start your build.
Good luck.
dude ,
start looking at some MOTEC ECUs since you have the $$$ then consider stroking the engine to a bigger displacement.
Bigger turbo (run single maybe? -for bigger top end output)
Edited by hicas_posse
Harley,
Good luck.
I agree completly and reliablity is my 1st concern and then worry about making perform well for time attack or track use. I still plan on driving it daily during the summer so no huge horrible laggy turbo, from what I have read the 2530's sound good or is there a better set to go with....I would like between the range of 500-600 hp tp the wheels and thats it
As for being built the GT block or N1 block and then the HKS stroker kit sounds good and then getting it blueprinted and honed. Any advice to make a nice built motor will be appreciated
If I were building something with that power at the wheels with that budget I would probably do something as follows:
N1 block
JUN 2.7L stroker kit (crank, rods, pistons)
JUN oil pump
9 litre enlarged and baffled sump (CRD in Australia could help you out with that and send one over)
JUN 272 degree 11.35mm lift camshafts
JUN titanium bits for head (buy this and the cams as a package)
JUN cam gears
Tomei gasket kit and head oil feed restrictor
HKS T04Z turbine kit (turbo, manifold, wastegate)
HKS Type R intercooler
HKS Type S oil cooler
HKS duel entry fuel rail
Sard 800cc injectors
Sard type RJ fuel pressure regulator
Bosch 044 pump in tank going to surge tank, with twin 044's pumping from surge tank
ECU of your choise
Youre then going to need some form of gearbox/clutch combination. I am a big fan of the OS Giken OS88 6 speed sequential box, but this might push your budget a bit (the box itself is $16,000 AUD or so) but then again if youre doing alot of the work yourself you will save greatly on labour costs.
Id also drill and tap an extra oil drain from the back of the head to the sump, as reccomended many times on this forum.
But that above combination would be an awesome street package in my opinion and run some impress 1/4 mile times too. It would easily put out over 400kw at the treads.
Edited by Amaru
what he said would be da bom^^...
Also the HKS 2.8 stroker kit with a set of HKS-GTRS turbos would be awesome!! Check out some of the well setup shop cars from japan such as the Mines R34 (my fav & track weapon), OS 3ltr (awesome) and the MCR R34(hks 2.8 + GTRS)...
I would suggest that 370awkw is acheivable with a set of 2530's or trust 517z's but the engine setup, tune & boost levels will be critical...
With a single such as a T04z you can pull 400+awkw easy but miss the midrange of the lowmounts...but great top end trade off.
my 2c, goodluck
^^^ All awesome suggestions
However, no advice is free, we expect pics when this monster is done.
And I reserve the right to act ina manner that is insanely jealous and cry like a baby if you crash it.
my 2c, goodluck
The 2.7L will rev to 10,000+rpm on pump fuel which is why the T04Z goes so well on it. I guess you could say it effectively moves your midrange up a few thousand rpm, as changing at 10,000rpm wont make you fall as far back down in the rev range as changing at 8 will :/
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
