hes well looked after he got satin sheets and all the works :/:(
And i whipped his ass and he had to do the food shop on his own..so we all know who is in charge in this relationship
Edited by Wildcat
Hey Wildcat, hyperdrive found that my rear wipers motor for the water spray is the wrong one :/ (it wasn't working, and still isn't :huh:)I have no idea why there is a wrong motor in there.
When my S1 arrived the rear washer did not work. The fronts were fine and the same pump is used for both.
The line to the rear wasblocked. You can get to it by removing the rear cover and the rubber gromets in the body and the tailgate. Disconnect the line and pump through and clean nozzle.
If that doesn't clear it and the pump motor works it would have to be the solenoid that opens the pathway for the water, or the line is blocked closer to the pump I have not got a clue where the solenoid is at the moment, but will search if you need more info.
Cheers 66yo. :):nuke:
I think I have stuffed up.lol
I checked again and it seems like there are two motor sounds when both washers are on together. Check and listen. Ifyou can hear the motor work when it should the it could be a blockage at the rear nozzle.
Its quite easy to get to the line via the cover and grommets in the back .
Cheers 66yo :nuke::/
:huh::)
Hey Wildcat, hyperdrive found that my rear wipers motor for the water spray is the wrong one :) (it wasn't working, and still isn't :huh:)I have no idea why there is a wrong motor in there.
Well im lucky enough that the water spray still works and comes out like its suppose to...the wiper just doesnt move...will have a closer look tonight or tomorrow when it eventually stops pissin down with rain :nuke:
Well im lucky enough that the water spray still works and comes out like its suppose to...the wiper just doesnt move...will have a closer look tonight or tomorrow when it eventually stops pissin down with rain :mad:
The PDWR got me. Its pissing pickhandles here and we love it. Costs $120 for a load of water. :rant::O
oh mister tangles :D i have faith..i just like to be independent and being a girl and all i would like to be able to do things that men think only they can do :mad: but of course hubby can look at it and fix it and i can watch ;):(
You like to watch....................... eh :huh:
hes well looked after he got satin sheets and all the works :mad::P
OUCH!!!!!!! Damn you ARE WHIPPED Mr GTST!!!!!!!!
While we are talking rear wipers...
Take a look at the length of mine! I have the fuse removed so it can't be turned on, if it is it just tries to smash the squirter nozzle off tailgate, pretty funny but a little scary at the same time. The wiper arm has Toyota stamped into it so it's wrong in more ways than one!
Anyone have a spare rear wiper arm? Or one they would be happy to part with? I will post a WTB in the trade section but will not be holding my breath...
Cheers
Luke
Far out Munch, thats a bit big... although I have to agree with who ever put it on... piddly little wiper on the back :P
66yo I think the problem is with the motor that runs the water, its the wrong one, The back wiper works and the fronts work with the washers.
I'mTOTALLY confused.
Is it correct to say (1) The front wipers and washers work
(2) The rear wiper works but the washer does not
(3) The rear washer works but the wiper does not
(4) Nothin' f**kin' works?
(5) Caus its pissin pick handles and I forgot to change the HW from solar to electric
we have all had to have cold showers and its buggered my night life.
(6) And if thats not enough the boys and I, successfully fitted a new water pump and
timing belt into a 180.
(7) God is good to NISSAN drivers.
Cheers 66yo. :D:D
how can the rear window washer motor be wrong? surely any washer motor will work with the 2 wires connected. i got both washer motors sitting in my garage doing nuthin (cant fit washer bottle with cooler piping), but i might need them later on. how about buy a new one stagea girl from nissan? they wont be much $$$ i'd imagine.
Yes it was a very easy job...(for the hubby) :laugh:
Was just a matter of pulling the cap off the wiper arm and tightening the nut... :laugh:
Little embarrasing after all that worrying to find that it was about a 5minute fix job..but at least now i have a working WINDOW WIPER :laugh:
:laugh::laugh: for everyones help and advice much appreciated
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
