just wondering, i could be wrong
why are twin turbo systems generally split with 3 cyl to each, rather than 6 going through 1 turbo 1st, then that gas going into the second turbo?
i mean in my book its doable...
and would mean u could run bigger turbos with half the ammount of lag, or half the lag of existing turbos..
Air comes out of all 6 cyl, enters turbo 1, turning compressor 1, exits turbo 1, enters turbo 2, turning compressor 2, exits into exhaust.
oh wait i think i figured it out........waste gate.....
but couldnt u basically remove the 1st turbos waste gate and the second one's wastegate regulate the flow?
Edited by illusiVe
https://www.sau.com.au/forums/topic/132511-twin-turbo-setup/
Nope, all the exhaust gas has to go though the first turbo ie no wastegate control on that turbo.
Take a look at the stupid exhaust manifold and complex plumbing on atwin turbo 13B or JZ.
It simply isn't worth the hassle.
:rant: cheers :O
It's done in big installations where they can use multiple stage turbos and multiple stage intercooling. The wastegate gas goes straight into the next turbo, but by the tim you need to start doing that you go with an axial flow design. Just not necessary on a car to achieve that level of efficiency.
didn't Greddy / TRUST do some twin turbo'ed and supercharged R32 back in the 90s? it was metallic blue.
I have a magazine kicking around somewhere - the exhaust side is a mess of spaghetti polished pipework and blue vac lines...
Anyone got more info on it?
From what I can tell staged turbos particularly on a petrol engine are complex to package especially in todays "shrink fit" engine bays . Most Diesels get it easier because many are said to be free floating ie no wastegates and that eliminates lots of dramas .
I don't know for certain but I believe Nissan tried hard to make an efficient compact setup for the GTR's but thats not to say its not very involved on the exhaust side of the engine . To be fair they got low innertia turbo rotating groups (ceramic turbine /aluminium compressor) and double the wastegate area of your typical single turbocharger integral wastegate . In pure race terms Fred would probably have prefered to use a larger single but Group A didn't allow for that . You gotta feel sorry for the V8 brigade , at least they could lament that it took two hairdriers to beat the "iconic" bent 8 . I think the legacy of being beaten by one would have been terminal ...
Production turbochargers have come a long way since 1988 and many of the benefits (and this is my opinion only) of twins are just not there anymore . Toyota is a good example of staged twins (I think ?) and later a larger single on the 1J / 2JZGTE . Their marketing arm may not have been able to stensil TT on the side of some Supras but arguably a bit more capacity (3L) and one adequate turbo made the 2J a good road engine (as opposed to a homologation special engine) .
My vote goes to singles and todays production cars seem to be this way . There are a few examples of twins as in one per bank on a V6 or V8 ie TT VG30 and Audi's RS6 and for packaging reasons its way to go .
Cheers A .
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
