hey guys, finally found my prob in racing my car, traction! i am now looking for some 16" micky thompson semi slicks for my car, if anyone has some that i can borrow :laugh: or if i could buy some that will be great.
Thanks, Phill
https://www.sau.com.au/forums/topic/132668-semi-slicks/
what for?
The street or to race at the track?
You dont need semi slicks, you just need to spend good money and get good tyres.
I had 243 rwkw in my R33 and ran 12.5 on 18 inch 265 Potenza 8000e. 1.8 Second 60 ft. Thats what most GTRs get with 4WD.
So many idiotic mates of mine always go and get slicks or semis, and there times are really average.
On the strip, If you have less than 300 rwkw in a skyline and need slicks, you just dont know how to drive
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2458448
best time was 13.3@105mph 1.9sec 60 footer on some runs.
starionturbo: the car has run 13.1@105 with 205/55/R16s baught second hand just to pass rwc. I dont need street tyres, i can run flat out slicks or mt radials.
2rismo: delivered to melb? how much per tyre roughly mate?
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2458571
what for?
glad someone said it :)
not having a go at LTHLRB...not at all. 205rwkw with no ECU or piggyback is a mad effort...but all these people using slicks to break the 12 sec barrier...I was always under the impression that slicks were when you were getting down to 11's and 10's....
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2459003
Personally I think that if you are drag racing, you should run semi's or full slicks. It's what the pro's do, and it shows the full potential in a time and MPH of your car's power.
Agreed. I was there on friday night at I ran a 13.43 with about 200-210 rwkw and my suspension setup is for drift/track. It's very stiff. I used semi slicks because I had them. Definitely helped. I'm no drag racer, just wanted to have some fun. Why not get some slicks. Easier than swapping or adjusting suspension...
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2460032
my suspension is stiff as anything, its more drift/track aswell. But i dont want to go making my ass end any softer because it will be shit for road. The car is making the power yes, thanks Dez for the compliments, thats about the most power i can get now is 209.5kw untill i get my pfc. But i haveto resort to slicks or semi slicks to get me into the 12s with a completely std ecu/injectors/turbo.
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2461631
If you're making over 200rwkw you DO NOT NEED semis/slicks/drag radials/whatever you want to call them. What you need is practice.
12.799 @ 107mph on Falken ZE326 buckets of crap with only 190kW.
Adrian
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2461868
Adrian
What suspension setup did the car have?
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2462489
got a quote on mt semi slicks, for the normal ones 255 x 16 its 280 or so and the others (discoloured) are 240, they had to use more powder to break it out of the mould, and the tyre is completely white PIMP STYLE. Does anyone know if that will effect the performance of the tyre?
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2468026
It will absolutely NOT affect the performance of the tyre. The factory seconds stock from Rocket is 100% guaranteed and warranted against defect (other than cosmetic, obviously).
Yes I'm going auto.
LTHLRB, I still reckon you should call Stuart @ Bezerkly Automotive and ask for a price - 02 42261888
Adrian
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2468291
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
