Ok... I thought i was going mad, but im not.
See here:
http://www.skylinesaustralia.com/forums/in...hp?showforum=70
Now look for the thread:
Road Rage Incident
It says:
Replies 19
Yesterday, 04:43 PM
Last post by: MK2
Now the last post is actually by Liz
I've noticed this in Forced Induction aswell yesterday where members have posted, but i cant see thier posts.
People post after them, and i can see thiers.
Its like the forum it outta sync or something nasty like the last time posts were going missin.
Have fun with this one
Cheers :huh:
https://www.sau.com.au/forums/topic/133019-posts-are-there-but-not-there/
I've been noticing heaps of weird things post wise over the last 2 days or so...The board seemed to be up and down a lot, and thats when I noticed things...
A lot of threads were saying Last post by Mavric, but the last post wasn't by him...
Other posts seem to disapear and then be in the thread later on or something like that...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
