  • Replies 96
*I suggest under the gateway bridge near cannon hill...
*Clear mountain (however this would not be a really wise due to the residents up there not liking buzz cars using the mountain for rally use at night.)
*Also the carpark at DFO was always popular.
*Out the back of the airport is good also just near hanger 3 (qantas's huge hanger). Out near pinkenba.
*Also under the story bridge.
*Cav Ave Goldcoast
yeah definitely different spots for different shots
my suggestion for a spot is open concrete or bitumen carpark, preferably a garden surrounding it, and some big white lights for the whole area to get a lot of car detail and reflection
something like a servo with a lot of lights and those young gardens they always have
Ok...
Those interested in actually attending this, please pm me for the details.
I want to get an idea of real numbers of those really attending this.
It'll start Sunday arvo at 4pm at Kangaroo point area and should finish up at around 6ish probably somewhere in and around the CBD area.
Afterwards, anyone attending this is welcome to come join us for a drink or 2 in the city somewhere.
We also have in mind highway driving photo shoots.
If we get enough interest, we can do this a bit earlier at around 2.30/3ish.
