Cheers guys, hope she does get done by motorvation if all goes well,
engine specs
Rb26std internals
Garrett GT30 ball bearing turbo
turbosmart pro gate wastegate
Custom Front mount
High mount Manifold
3 inch exhaust magna flow muffler
remote oil filter
oil cooler
Wolf3dV4
Car specs
r33 gts-t gbox
truckline 1 piece tail shaft
Ford 9 Inch 4.11 gears LSD
VS commodore rear discs
toyota 75s front calipers
Koni adj all round
Lovells heavy duty lows all round
bosch fuel pump
lift pump
surge tank
battery in boot
drop tank
gauges boost oil
thats about it
has done 13.3 @ 111mph
but put hole in oil filter ended my night after 3 runs
Edited by boostinlj
all i have to say is your a bloody champ. my next car is gonna be an LJ... ive always wanted one. never ever thought to put a rb26 in...
Marry me :woot: haha jj
thats your solution to finding a good car isnt it? marry someone with one already! :D
i need to find me a chick with a skyline to make up for when i sell mine :laugh:
I prefer the LX hatch myself. :O
However, I've already driven Toranas. I'm not gonna go from using cell phones to cup and string. Luxury, quiet high powered cars 4 lyf yo.
So when are you going to upgrade and get one of those hahaha just jokes
And disko tek im getting scared,marrage is a big step unless you will give me 45 million dollars then i will comprimise hahaha
Edited by boostinlj
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
