Just trying to confirm something.
I got my car tuned with a z32 AFM that up until that day had been sitting in my garage for about 18 months and I've just found out had been unused but presumed to work for quite some time before then.
Anyway, the tune was good, it ran well but over a few days it seemed to deteriorate and I put it on a dyno where the air/fuel ratios went under 10 and it pinged.
I have since been steadily dropping the boost to now 7psi to stop it pinging.
The z32 AFM I believe maxes out at 4.5 volts.
I have seen it at 4.4 volts at 5000rpm with as little 10psi so it has been suggested that the AFM is dying or at least has something wrong with it.
My question is:
If we are right about the AFM showing far too much voltage for the actual air flow, it makes sense that it would be overfueling but can overfueling cause it to ping? Or is something else up?
https://www.sau.com.au/forums/topic/133359-can-overfueling-cause-detonation/
Mine was running in to the 9's (flat lines at 10 on the dyno as thats as low as the wideband reads) and there were no signs of detonation.
Sounds strange.
I gather you are running new fuel? Its quite possible the old stuff went off as it is 18months old. :O
Z32 at 4.5v. What sort of power are/were you making?
Mine hits 4.3v on the standard turbo running 10-11psi.
well. it must of been making some power to reach the limit of the z32 afm.
to much fuel can cause pinging. not directly, but by carbon buildup in the cylinders. this glows and causes pinging. not detonation.
this is a pretty obviouse question but there isnt any air leaks is there?
also worth checking is the timing. if the cas hasnt been done up tightly it can move and the timing can change.
in throey. if its dirty it will take more voltave to keep the element hot. given the same volume of air.
coz the dirt will be insulating the film.
give it a clean(if its dirty) this will restore it to the factory parameters. if that makes any sense.
also oiled type air flow meters are no good for longevity on any hotwire or thick film afm (z32) it oils up the element and the dust sticks to it.
Wouldn't that mean less voltage?
If you had an air leak in the intercooler piping, or a venting bov opening, the afm voltage will go high, as will turbo speed.
Well with the old ECU, auto and stock AFM I was making around 255rwkw.
Then I did a manual conversion and put a pfc and Z32 AFM in. Tuned on a dyno that seems quite happy it made 300rwkw. This was at 11.8 A/F ratios I'm told.
Tried to run it on a dyno I knew and it ran 225rwkw, pinging and rich as feck. Didn't get too close to redline cos of the pinging.
Cubes - is that standard turbo but RB30?
Fuel is new and fine. 3 types tried.
I don't think there are any air leaks but I will check tonight.
The pinging doesn't seem to happen with heavy boost low to mid rpm, more like any boost high rpm, like over 5000.
My theory at this stage is, AFM tells PFC there is much more air than there really is, PFC puts lots of timing and lots of fuel in.
The only other thing I can think of is that the lambda sensor used to tune it was out and something is wrong with the tune although that wouldn't account for the pinging since it wasn't pinging at all when it was being tuned and on my test drive (and I gave it a good quality test drive).
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
