If you guys can't post informative or helpful anwsers, then please dont bother posting your rubbish on the forums. It's not wanted, needed or required and all your proving is your a post whore who is about as useful as belly button fluff.
https://www.sau.com.au/forums/topic/133386-skin-selector/#findComment-2499625
Lol bellybutton fluff
Im having the same problem i wanna change my skin!
https://www.sau.com.au/forums/topic/133386-skin-selector/#findComment-2508606
  • 1 month later...
What if you change your skin preference in you control panel?
I have tested this in IE and FF and it works fine for me, its hard for me to fix when I cant replicate.
at least they replied to the thread...
*yawn*
https://www.sau.com.au/forums/topic/133386-skin-selector/#findComment-2636573
  • 3 months later...
*yawn*
I can't even find that option in my control panel....its not in board options...
P.S my skin selector still isn't there. Latest version of firefox
https://www.sau.com.au/forums/topic/133386-skin-selector/#findComment-2942117
In an effort to try and help this along, here's a screenshot of what happens when I try and access the skin selector.
I can't find any option in my control panel, the only place i can find an option to change it is at the bottom of the page, perhaps im not looking in the right spot in the control panel?
anyway, here's what happens, the box drops down, but it's empty.
(mozilla was doing the same thing, i've since upgraded to the latest firefox, and it's still no different)
That probably doesn't help at all, but at least it sort of shows you what we're talking about. :happy:
https://www.sau.com.au/forums/topic/133386-skin-selector/#findComment-2952592
Yep im the same stuck on light skin dam it!!
Most peeps are saying the last time SAU crashed it wiped the selection away and what ever skin you have now you are stuck with :)
So crap as I have never seen the dark skin and dont get to see the new banner :)
https://www.sau.com.au/forums/topic/133386-skin-selector/#findComment-2961704
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
