  • Replies 129
Posted Images
Got mine today - very happy with them! (But like someone said - the 'wrinkly' could be waaaay more wrinklier!) Have done the drivers seat at this stage, pics attached
Hor-f**king-Ray
kinda got mine but didnt, no one was home to sign for it so its at the PO, mum is getting it for me tomorrow :D put them in saturday
YAY
Finally got my covers & seats ....
i've got passenger & back seats done as well as the centre console (they did it for me), l'll be doing the drivers on sat/sun, so l'll post up pics then.
But DAMN they smell good, and look HOT!!!
Guys please take care installing the covers they are very very tight...patience needed..
Here are some pics ultimate sent me of head rest installation, hope it helps some of you..
that's wicked!! wish I got onto it!!! PLEASE let me know if you get another group buy going, otherwise I may have to look into it myself...
Keep the pics coming!
Nice seats those ... look even better in my car. :woot:
But great pics Jetdat ... my only concern was this part of putting them on, so now l won't need to worry
Edited by -FUZZY-
I have actually left the plastic thingos that adjust the headrest height under the cover - I just made 2 small holes and poked the headrest poles through (adjustment is made by pinching the plastic thingo together through the cover) .... I think that looks better.
Back seats were very easy about 10mins each side. Fronts seats are a bitch to do on the R32 GTR seats. The fit for the back rest isnt so great, the hole at the top looks pretty ordinary and right at the bottom is too loose. But in all still great value for money
Hey mate, can you send me some pics so i can show ultimate this problem?
must say a big thanks to Jetdat, the organisation and information presented thruout the buy was exceptional. very happy with how it all went.
Cheers mate :)
LOL are you shirtless in the background ?
Do i sound like a man or does my hand look like a mans hand?!?!?! :)
Thats my bf in the backround.. lol..
Agreed!
I did the same mate, I also left the lubar support under the cover I never adjust it anyway
and D I F yes they do look like man hands :)
just kidding
cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
