hello all, as the topic says, im moving to QLD. where u may ask.. Emerald in fact!!
just wondering if any one lives there or Rocky or any where close
any way would b good 2 meet any one up that way,
Hey i'm not aware of any members that live up there but i work out there occasionally (just did 3 weeks about a month ago). I hope you have accomodation and a decent wage sorted cos its freakin expensive to live out there! rental prices are mad..
Didn't spot any skylines up that way - its v8's, landcruisers and minitrucks as far as i saw.
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2502465
Emerald is quite some way from the big smoke...
But Ska is up that way and would love to spot you driving around. He gets all excited when he sees a skyline cause there is not much up there... Other than dust and heat...
Emerald is about 250km inland from rocky...
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2502468
its no good owning a decent car when most of the road u have to travel are crappy outback ones, so that is why most ppl who live in these places have 4wd etc bcoz they need them to go offroad and also for there farms. skylines are just impractical out in those areas
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2506339
actually daz most of the major roads are better quality than you'd think, i was pleasantly surprised. Still, if all you can afford is a farm shack then might be a different story. A couple of streets in toowoomba and inner brisbane have by far the worst major roads i've ever driven on in qld.
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2506961
Most of the main roads are OK due to the fact there is a lot of traffic and money out there. I have seen a few lines around Moranbah and a few more in Mackay. Not too maney on this site. Also the amount of 4WD's have got a lot to do with the amount of money people make there and the fact that nearly everyone owns a boat and use the 4WD to tow them. I lived there all my life. Just moved to Brisbane 12 months ago.
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2507000
any of u actully been there, ROADS are all seald!!!
only off road shit is if u do own a farm,,,
i got offer'd a job working in the mine.. money will b no problem, no that it is now!, and free Accommodation, what else do u want...
another sik car build up is on the cards as soon as i get up there.
narrow'd it down to a few cars.. S15 spec R, R34 GTR or EVO 6 n up...
any way if any of u R Actually in rocky / emerald send us a pm...
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2523868
Haha, i'm from Toowoomba and that's very true but you never really notice it because you can never get over 45km/h due to the number of old people on the road.
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2532356
In Cairns....
Bout as close as you'll get
but if you are up this way let me know :P
https://www.sau.com.au/forums/topic/133559-moven-2-qld/#findComment-2556270
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
