Any chance I could get a VIN check on this one?
This should be an R33 GTR Vspec, I believe its series 2...
VIN# : 6U900BCNR33003916
Thanks,
Gareth
Feel free to PM me a response. Its quite urgent because the seller wants an answer ASAP...
Edited by some_cs_student
Hi, Is there someone that can do a quick check for me on a non-skyline Nissan??
I have a '94 Nissan Cedric, VIN#: PY32-770579
Model# MLEARUNY32EDAE009Y
Can somebody please check whether this model came with an electric radiator fan (thermo fan) as well as the clutch fan? I believe they should come with both, but mine only has the clutch fan (and i'm having overheating problems!)
As it's in japanese it makes it very difficult to tell you what it has.. I've found it - the VIN is actually: PY32 - 000579 for anyone that can look it up in japanese..
I could go through all the parts, if I get a chance i'll check it out..
LOL! Mine is identical to yours! ECR33-114098
Cept mine was made later that year.
Do you have the M-spec front lip? I'm pretty sure that code means you and I have the M-Spec R33 series 2.
nah mine doesnt have it... but doesnt mean someone has stolen it off me :D
i dont think mine has any options.... only has twin airbag. no abs or a-lsd that i can c anyhow...
