Can someone check this engine number for me. Thanks guys.
RB26 D20423A
For the record I got this number from the shop at which I ordered my rb26 so i am not sure it is the right number. If this is not the correct format for an engine number let me know. I dont really trust this shop but they were the only ones who claim to be able to get an r33 motor so I am checking everything i can to verify if it is a 33 thanks.
nah that wont work... it should be like HCR32 XXXXXX or ECR33 XXXXXX for e.g
also the "D20423A" part doesnt evan fit into fast... u can only put 6 characters in :ermm:
RB26
No problem, but maybe you need to change your ID >_<
Still looking for a GTR, this is one car that I have been looking at in japan...just wanted to check the build date before I pursue it any further...in the end I might have to my id. :)
Also can anyone do a breakdown of this code.
GGJPRQFR33ZDAGJ
Thanks again for the help guys.
Edited by 96_GTR
All it came up with is the info below. Obviosly need the vin for a compltete build date and so on.
Still looking for a GTR, this is one car that I have been looking at in japan...just wanted to check the build date before I pursue it any further...in the end I might have to my id. >_<
GGJPRQFR33ZDAGJ
Thanks for the quick reply again kjb_r33. Much appreciated. I guess I wasn't concise enough in my last post.
Is there a way to tell what the letters mean in the Model code GGJPRQFR33ZDAGJ that FAST has given.
all i can find on it.
Let's work through one... GGKBRTAR33VDAA---B
The first digit defines the body type... In this case G for 2 door Coupe... (It's B for 4 door Sedan)
The next 2 digits define the engine type and size (note: not the fact that it is NA or Turbo)... in this case GK for RB25DE(T)
The next digit (4) defines the drive type... In this case B for 2WD...
The next digit (5) is R across all R33's... I'm unsure of its significance... Some translation is required here...
The next digit (6) defines the model spec... (eg: GTS, GTS25, GTS4, GTS25T/M, GTS25/S, GTR, etc...) In this case it is T for GTS25T/M + GTS25/S (note: we still don't know if it is NA or turbo yet)
The next digit (7) defines the transmission... In this case A for 4 speed auto... (It's F for 5 speed manual)
The next 3 digits (8, 9 & 10) define the Model Series... In this case R33 for (duh) R33...
Now comes the tricky part...
The next digit (11) defines the induction system... In this case it's V for Forced Induction... (It's E for EGI / NA)... Some further translation is required here...
The next digit (12) can be either D or Z... I'm unsure of its significance... Some translation is required here...
The next digit (13) is A across all R33's... I'm unsure of its significance... Some translation is required here...
Shown below are all possible entries for the first 13 digits of the R33 Model Codes...
Note that different years have different designations for the digit (mainly to cater for the GTR's and GTS4's)...
R33 Model Codes (14-18)
Erghh... So many options...
The only one I have semi worked out is the last digit (18) which will be A if you have an Active LSD, B if you have ABS, and C if you have an Active LSD and ABS... There are heaps more options for digit 18 though...
It appears digit 14 is mainly focused on the wheel and tyre sizes...
It appears digit 15 is mainly focused on the electronic options (eg, ASCD (cruise), GT spoiler, etc)
I am unsure what digit 16 is mainly focused on...
It appears digit 17 is mainly focused on the AV options (eg, CD, MD, Stacker, etc...)
Edited by kjb_r33
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
