I cant find a Blue Plate (nissan build plate) on my R32 GTST?? Only has a green compliance plate on firewall and aussie VIN etched on strut tower but not original jap VIN (which you need right?)
your vin might look like 6u90000er34002654 (posted earlier by someone) -- the original chassis number would be ER34-002654, which is what we put into FAST
Thanks Goofy,
Is there any chance u could tell me if this is a N1? I dont think it is but some1 claims otherwise
Eng no: RB26066194A
Vin: BNR32304039
Cheers
I'm not sure how to tell from the numbers (yet) - but apparently if you look on the side of the block and it says 24U its N1, if its 05U its standard
Edit: ok, KBNR32RXFS7 AA is the option codes it comes back with
It needs ZN at the end instead of AA to be a N1
Remix-: your pics not loading for me :)
Edited by Goofy[HSK]
Am I typing anything wrong for this to be run through FAST?
blockquote><p><a  href=http://img215.imageshack.us/img215/695/hnr32003113yf8.th.jpg' alt='hnr32003113yf8.th.jpg'>
If you put the option line in FAST first (KRNR32RGASLMAB) it then brings up another box asking for the vin.
It gets all the details about the car (gts-4, auto or manual etc.) from the option code - then just gets the production date from the vin. Colour codes didn't come up - i added them from your plate.
' date='23 Aug 2006, 10:16 PM' post='2433414']
My aussie VIN doesnt have anything to do with the original chassis number.
MY aussie VIN is 6F9IMPORTTH9K**** (I left the last 4 digits out).
Why would they have removed the original blue plate? Is that even legal?
I guess I have no way of finding out anything about my car, will make ordering parts from nissan hard too!
hmm... interesting - is there any other numbers on the firewall at all?
Hi guys. Never needed this thread until now but just want to check something. If someone could help out it would be much appreciated.
Can this software give part numbers for engine parts? Am I in the right place or is there some other software for this sort of thing?
I have been told that R34 GTR RB26DETT rods have the same part number as R34 GTT RB25DET. Could someone please confirm this for me or send me to the right place?
Thanks a lot.
Adam.
Thanks a lot.
Adam.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
