Can someone help me out, My mate got a R32 GTR and he was told that the engine had been changed to a R33 GTR. He want's to make sure it is a later model and not an early model.
The engine no. is RB26024496A
Thanks in advance guys.
I pretty sure you're not able to do searches based on an engine number :P
HCR32 - 295948
Here you go :unsure:
Details on your car:
* R32
* 9306 = June 1993 build
* 326 = crystal White
* 2K = 2 door
* RB20DET = 2 litre turbo
* HI.2WD = Hicas 2WD
* GTST.M = GTST Type M
* MT.F5 = manual transmission 5 speed
Is there another way of finding out?
Not that I am aware of...someone else may know though.
ECR33-054695
This number wasn't present in my FAST, sorry :(
ECR33-103990
just wanting to know as much as possible like the features it has, whether it has abs, sunroof etc
Here you go :(
The options list is the small screen. Translation could be rusty so by all means get another to check ;)
14 = no option here
15 = rear wiper
16 = rear strut tower bar + trunk lid trim + GTS25T type M
17 = Skyline Sound System (which probably means base spec?)
18 = (passenger?) airbag + ABS
HCR32 - 030786
Here you go :)
Hi,
I've got a chasis No. to check if that's okay: ECR33-054695
Thanks,
Adam
Doesnt work in my FAST, but hasnt been the first time a VIN hasnt worked in mine and worked in others.
ey all. can someone check this one please?
ECR33-103990
HCR32 - 030786
many thanks :sorcerer:
could someone please check BNR32-304732 KBNR32RXFS7-MA.. is this car an N1?
thanks heaps in advance..
Well it looks to be not an N1 edition.
The chassis number 304732 indicates a '93 model.
The KBNR32RXFS7 is the same as the stoandard GT-R's, but the last two numbers usually read AA. Although it may be different for a 93 - the AA appears on the '94 FAST listings....
Bear in mind there were only ever 228 N1 built.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
