hey guys,
tonight i was driving down the freeway in 3rd and noticed as soon as i put the foot down to change to 4th gear my engine light flashed and then didnt come on again.... i have a stock r34 only mod is a catbak zorst, wat does it mean when the engine light comes on? the car felt normal though it didnt sound like it was missfiring or boost cutting... any help will be appreciated thanks
https://www.sau.com.au/forums/topic/133889-what-have-i-done/
you can check the ecu to see what the fault was. I'm not sure how its done with r34s but someone else might know. Might be the same as for r33's, if so, search it cause its been posted a few times. If you take it to nissan they can check it with datalogic and see whats the problem. Could be nothing...
Hello,
More than likely it is O2 sensor, this happend to me once.
But do a check.
The mechanic at the time bridged some point up with a wire and the dash lit up several times to
notify us of the fault and which sensor it was.
I am not sure if this is the same for R34's. :)
i think i need to take it for a tune?
congrats on finding a PFC where your standard ecu should be :ermm:.
Yep, get a touch up tune just to make sure everything is ok.
With a PFC the check engine light generally flashes if the knock reads >60. I'm guessing it knocked a little when you floored it and put the engine under load a little. Just get a touch up dyno tune done :P.
I had this problem when I first picked up my r34 turbo from the dealer.
He did the diagnostic and it turns out it was a speed controller. He said just keep driving it till the part comes in... Then 3 weeks later the warning light switched off and no problem since... Though I have had the speed controller replaced just in case but it is amazing what sorts of warnings this advanced electronic controlled cars can give you.
Battery was out of the car for one week whilst a body kit was installed, then the driving to work on the F3 in Sydney to Gosford car turns off and does some sort of emergency breaking, turns out one of the battery cells had died and was only causing a fault occassionally when more then normal power was being consumed. Naturally this was a wet day, so had headlights, wipers, stereo and the driving aids were occassionally kicking in.
Anyway, moral of the long and pointless post :ermm:
Find yourself a good "import shop" that you can build a relationship with so that you can have problems solved easily and without being ripped off or car damaged by a mechanic who does not work with imports.
Also just incase you didn't know where your diagnostic plug is, it is below the steering wheel to the right it has a little latch where you can unplug it and then plug it in to a diagnostic tool or workshop... or even one of these great new toys from greddy I seen in the latest high performance import magazine.
Drew.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
