  • Replies 104
Originally posted by Pva_Glue
Why is that?
and pictures plaese... nice shot of girlies too :)
cheers
Joe
Cause your a madman without a turbo u dont need one! And society is better off that way :uh-huh:
Pictures up tomorrow u know we needed Sun not shade it would of made for much better pics!
You got the footage of girlies i was just facing you the whole time smiling :O :O
Originally posted by macka
HeHe where were u?
We were all there...........i rocked up 1230
Under Narrows bridge South perth side
:lol: It looks as though i must have left just as you rocked up DOH!! ah well just my luck.... i waited round for a little while then called IMACUL8 to see if he knew what was going on.. but he wasn't cruising.
So yeah i then left about 25 past.... maybe next time... :dump:
Guest Rhino
Unless you were in a white R33 4-door, we didnt see you 25GTT.
We arrived at about 12:15pm and waited for macka to return from dropping his passenger home. He arrived around 12:30.
Where exactly were you, we were at the carpark directly underneath the Narrows on the South side of the river.
Yup thats the one...... I think i hopped off at Mill point roads then followed it round till i saw the carpark under the bridge, couldn't see any skylines there so went to the next car park with my friend, Harrased IMACUL8 and then no luck, Spewin i missed yas! would have been nice, Twas a beautiful day for a cruise.
Ended up going to Cott for lunch with my gfriend and friend had lunch then mosied on down to Freo for a bit.
I know this is besides the point but you know the famous pylon that people used to jump off at Cott, well they have now changed it and put a spikey point on it so no one can jump off. Cottesloe was always known for the pylon that everyone used to Jump off and now it is gone..... I have never jumped off it myself but man it looked FUN! :lol:
haha yeh the pylon
its the best at about 10pm on a sunday summer arvo after the cott:P
sharks put a bit of a dampener on swimming at night though lately... we saw ur car 25GTT, me mack and a couple of other guys cruised to freo for lunch after meeting at carpark...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
